Follow on from recent “won’t start” post. Engine was running rough, then wouldn’t start. New Hall sensor was fitted, and I assumed that was the poor running problem fixed. Wrong! So tried changing plugs, emptied out fuel and replaced, added injector cleaner, balanced throttle bodies. Something seemed to have worked, running about 90%, so set off home. By the time I got back, it felt like it was running on one cylinder, but both exhausts were hot. What would be the next check, replace coil? Injectors? Any tips much appreciated.
