Issuds
Hi everyone,
I have recently purchased a 2011 R1200GS with 35K miles and have an issue which I was wondering if people had experience of.
When the bike is cold it starts okay but will not idle without some throttle input, as soon as there is some heat then it will idle but throttle response is not great, this improves after a couple of minutes.
I had a look at various settings with GS911 and the throttle position only reports 0% to 76%. Having looked at this forum there are various posts on reseting the TPS by disconnecting the battery for 10 seconds then turning the ignition on and opening/closing the throttle to set the position, nothing has changed. Any idea what I am doing wrong and if the TPS would be the first item to look at?
Thanks for any advice.
