E5 all day long. If you keep it fresh there will be no issues even using E10 occasionally, just dont leave it in more than 2 months.
Key thing is if and when you are putting the Suzuki away for winter , then run the tank and carbs dry. Modern fuels even E5 still have ethanol in which is hygroscopic and it causes corrosion in the old 70/80’s mixed metal carbs.
If you want to occasionally run it over winter then use Briggs and Stratton Fuel Fit. That what all the commercial gardener boys use.
