Reasonable review IMO. Interesting that Mike finds the screen "very effective, especially when raised" while 2 other reviewers described it as not very effective. Personally I think it works pretty well, and no buffeting as with a V85TT, but if I want still air it would need to raise up about 3" higher. Also it jiggles around over bumps when raised, so I just lower it when on gravel roads. It's fine on smooth roads.
He's the second one I've read that's repeated "And because it's a Guzzi, it clunks loudly when you tap it into 1st gear. Wouldn't want it any other way." WTF? I've never had a Guzzi, car, tractor, or any motorcycle with a dry clutch that "clunked tapping it into 1st gear" ? It's a wet clutch thing.
Yep the gearing is a little short IMO, but it's typical on many adventure bikes which are derived from sport or sport touring models, unless the manufacture takes the effort to make internal changes to the ratios.
