***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 17 to 32 of 108
Thread: Anyone had an indicator switch go on a GS (Solution)
  1. #17
    Senior Member
    Join Date
    Jun 2008
    Malvern, England
    Posts
    127
    New switch assembly fitted today. I don't know the price here but they're $250 in the U.S. so I think the extended warranty probably just paid for itself!
    Tibs
  2. #18
    Senior Member
    Join Date
    Dec 2005
    Brussels, Belgium
    Posts
    370
    Here's a solution for the 1200s that have indicator switch problems :
    http://www.ukgser.com/forums/showpos...80&postcount=6
    Cheers,
    GSband.
  3. #19
    Senior Member
    Join Date
    Nov 2008
    Going RTW
    Posts
    1,486
    I also had a long thread on this and did this approach. Has only lasted a week though and I'm commuting without indicators at the moment!
    Best bet is to get _any_ 1200 switchgear right or left and cut the switches out as they are all the same. I've just sourced one for £12 delivered.
    Also, be sure to grease the switch tops so that they don't dry out and crack.
  4. #20
    Member
    Join Date
    Apr 2009
    bournemouth, england
    Posts
    23
    Thanks Aidan i knew the micro switches would be available somewhere. Saved me a fortune in time and money Ta!
  5. #21
    Member
    Join Date
    Apr 2009
    Posts
    23
    ooops spoke too soon. What kind of switch do they call them in tech jargon cos cpc dont seem to have them any more.?
  6. #22
    Nice but unfortunate husband.
    Join Date
    Nov 2004
    South Armagh, Ireland
    Posts
    12,815
    Quote Originally Posted by jigweed View Post
    The CPC part number was SW01809. No Longer available I'm afraid.
    C&K (in the US) seem to manufacture these switches and list part number C & K - K12CBK15N - Tactile Switch. Link here.
    Newark (in the US) give a part number K12C 1 5N which is the C&C switch. Link here.
    My daughter lives in San Francisco so I'm thinking of buying some, having them sent to her then collecting them when I'm over there in June and bringing them home.
    BSD ordered a batch a few years ago and if memory serves they cost £12 delivered here, but hopefully I could beat that if my plan works.
    If you have no luck getting sorted Jigweed I think I might have a spare one here in the shed and we should be able to get you sorted.
    There are two opinions of the GS. There are those who have ridden one who think its fantastic and there are those who haven't who know its crap.
  7. #23
    Member
    Join Date
    Apr 2009
    Posts
    23
    Thanks so much Aidan you're a star. Ill endeavor to source them myself as neither of mine are working at the moment so can't wait til June. I would thoroughly recommend going into business though on these cos they're in demand it seems. Thanks again.
  8. #24
    Member
    Join Date
    Apr 2009
    Posts
    23
    Hi Aidan,
    I have been trying to source these from europe but so far to no avail so i wonder what the timescale would be were i to order some through you? Thanks Duncan
  9. #25
    Member
    Join Date
    Apr 2009
    Posts
    23
    Just wondered if you might be able to get them sent to your daughter earlier and she post them to uk. But if that's not possible i understand. Cheers
  10. #26
    Join Date
    Nov 2007
    Gloucester
    Posts
    3,118
    I had a similar problem and it was simply corrosion on the contacts on in the switch, same with my heated grips, I took the switch apart cleaned with fine wet and dry paper, and put it back together and they both work fine, its a bit fiddly but not difficult.
    ''Rules are for the obedience of fools and the guidance of wise men''
    www.thektmforum.com for all your ktm needs
  11. #27
    Member
    Join Date
    Apr 2009
    Posts
    23
    THanks Bowser, believe me i have seen the guts of these things a good few times now and cleaned and precisely reshaped the tiny connectors but i think they are seriously shot now. The rubber boots were both perished and i think thats the only protection they have. I also get wet a lot so it all adds up to nasty conditions for a poor microswitch. But thanks for your input. Dunk
  12. #28
    Member
    Join Date
    Apr 2009
    Posts
    23
    I might have found some in the uk. Its a bit difficult to see properly cos of the rubber boot covering the actual switch but the part number seems the same. What do you think?
  13. #29
    Member
    Join Date
    Apr 2009
    Posts
    23
    What a Dork. The part i have found is here. Forget to add the link didn't I. Anyway i've ordered a few, they're not in stock at the moment but should be getting some in soon.
  14. #30
  15. #31
    Senior Member
    Join Date
    Mar 2009
    wicklow,ireland
    Posts
    671
    Quote Originally Posted by Aidan1150 View Post
    if you come across the switches aiden,keep one for me,sprayin it wit wd~40 wont last forever
  16. #32
    Join Date
    Feb 2005
    Lancashire
    Posts
    2,959
    How many have you ordered, minimum quantity seems to be six? I'll take a couple of you if you've any spare
    Andy.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
