***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 65 to 80 of 108
Thread: Anyone had an indicator switch go on a GS (Solution)
  1. #65
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    Lost my indicator cancel button yesterday, everytime I used the indicator I had to hit the hazzard button to cancel them
    this button, is it not just a case of taking the button apart and cleaning the contacts?
    I've not looked into yet. if the button can be pulled apart and contacted cleaned thought that would sort it.
  2. #66
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    wow, postage is little high, £12 for two to be delivered. Two is only £7
    Think I will order some anyway. Does it have the wires coming out of it or is it a case of soldering the wires inside? the picture shows wires coming out?
  3. #67
    Join Date
    Jun 2006
    Islandmagee, Co Antrim NI
    Posts
    9,595
    Nope there are two "prongs" that are divided by a plastic wafer when you push the button the plastic slides down and the two prongs contact each other and a circuit is made
    They are very flimsy and do not stand being twiddled or moved at all
    What you can do is strip it down and if you are lucky the switch has water in it and the rubber sealing ring is perished or gone drying it out and filling with vaseline can be a good interim solution in fact my switches are all flooded with vaseline now Poor Design number 440 for 1200's but only poor design number 5 for 1150s
    if it's full of blue pooh then it's shagged End Off
    Either buy a used switch and replace BUT clean and vaseline everything before fitting or use a button from a damaged one to replace yours BUT not an ABS one they work back to front! making contact normally but breaking when the switch is pushed
    Quote Originally Posted by garvey2003 View Post
    Oh Great and Wise Deity, Grant me the serenity to accept the things I cannot change,
    Courage to change the things I can! And the wisdom to know the difference!
  4. #68
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    Does any other BMW have the same switches in, like the K for an example.
    Doesn't matter about the switch just the buttons.
    The secondhand world for GS Switchgears seems to be like Rocking Horse stuff
  5. #69
    Join Date
    May 2010
    Wandsworth, London
    Posts
    3,000
    Hi all, I think I have this error now. Just came from BM today and they wanted 180 odd without labour to replace both. They didn't even open the switch as it was not covered under extended warranty...even though the bike is only 33 months old!
    Can someone please tell me: can I just unscrew the 2 halves of the switch gear without anything wanting to spring out? I don't have a workshop so all work is in the bright sunshine ...and on the pavement so would prefer to know if some little spring will erupt when I unscrew the 3 bolts of the switchgear. On both sides of bike as all indicators go intermittently andthen wont cancel.
    I'll clean and grease it before proceeding with a replacement part (thanks to their £12 delivery) and my lack of soldering skill....
  6. #70
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    I know what you mean, £12 for delivery! shocking
    I'm keeping a look out for an old 1100 switch so I can use the internals in my 1150, think its the cheapest option
  7. #71
    Join Date
    May 2010
    Wandsworth, London
    Posts
    3,000
    thanks: Can someone please tell me: can I just unscrew the 2 halves of the switch gear without anything wanting to spring out? I don't have a workshop so all work is in the bright sunshine ...and on the pavement so would prefer to know if some little spring will erupt when I unscrew the 3 bolts of the switchgear. On both sides of bike as all indicators go intermittently andthen wont cancel.
  8. #72
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    Quote Originally Posted by adventuredon View Post
    if it's the same as mine (1150) then it will be fine, nothing pinged out of mine. Four screws and a couple of plastic planels and away you, all in bits
    Simple design just shame the internal buttons are crap.
  9. #73
    Join Date
    May 2010
    Wandsworth, London
    Posts
    3,000
    awesome, soon as it thaws, ill have a go!
  10. #74
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    My right ones have now packed up for good
  11. #75
    Join Date
    May 2010
    Wandsworth, London
    Posts
    3,000
    well if youre going to place an order with a £`12 delivery fee, let me know as I may also need to order some. Unless BMW offer a warranty replacement. BTW: how many inside switches for both left and right?
    No ESA, just ABS, info and ASC on the bars. Guess right side is 2, left side anyone?
  12. #76
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    will do, striping mine down this weekend. but think mine are dead.
    Not to keen on the soldering but but's a lot cheaper than buying a secondhand control
  13. #77
    Nice but unfortunate husband.
    Join Date
    Nov 2004
    South Armagh, Ireland
    Posts
    12,889
    Take it easy when soldering Garvey as the wee switches melt very quickly if they get too hot. Don't ask how I know that.
    One of these is overkill and is to be avoided.
    There are two opinions of the GS. There are those who have ridden one who think its fantastic and there are those who haven't who know its crap.
  14. #78
    Senior Member
    Join Date
    Jun 2012
    Swindon, Wiltshire
    Posts
    188
    the one I have is like this
    http://www.maplin.co.uk/30w-soldering-iron-32909
    just cheapo one, should I invest in a better smaller one?
  15. #79
    New Member (less than 15 Posts)
    Join Date
    Aug 2012
    edinburgh
    Posts
    8
    Having issues with the L/H indicator and found this thread which is handy
    Ordered 4 switches from mouser.com end of last week and in the meantime have managed to source a complete switchgear set for the L/H side so all good and working............which is just as well as it appears that the micro switches are different on 850's than they are on the larger bikes....my fault for not checking.
    Anyway........... I now have four switches sitting here that arrived today, still all wrapped up in the bubble wrap they came in, which cost £32 delivered
    Anyone need some switches
    Dont expect to get all the money back but how about £6.50 a switch........any takers??
  16. #80
    Maximum Mayhem Click here to find out how to Subscribe
    Join Date
    Jul 2008
    Breedon-on-the-Hill
    Posts
    1,158
    Click here to find out how to remove these ads
    Quote Originally Posted by livinlos View Post
    Hi,
    Yes please, I'll take 2 if still available. Is PayPal Gift ok?
    Cheers,
    Mick
    PS. You need to subscribe so you can send and receive PMs and access the Sale section; best £12 I've ever spent!
    livin' the dream
    2k R1150GS '05 MX-5 1.8
    Ok, so I could only be young once; but I can be immature forever!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
