***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Page 7 of 7 FirstFirst ... 567
Results 97 to 108 of 108
Thread: Anyone had an indicator switch go on a GS (Solution)
  1. #97
    Join Date
    Jul 2004
    Nantwich, Cheshire, England, EU
    Posts
    1,060
    I just completed my right hand indicator microswitch that stopped working.
    All I can say it is a fiddly job. The new microswitch when installed in the white collar stood about one mm above the level of the cancel button. So when installed, the orange indicator lever was depressing all the time.
    So, had to file a bit of the plastic node on the lever.
    Now it works OK and hopefully for another 13yrs.
    A GOAL is an end toward which some specific effort is directed!
    Go forth and prosper!
  2. #98
    Join Date
    Mar 2010
    Port Talbot, S.Wales
    Posts
    39
    Anyone have any contacts re. obtaining one of those replacement tactile micro-switches for the LH indicator ? Mine has just given up the ghost at 87K
    Great thread, very useful info.
  3. #99
    Nice but unfortunate husband.
    Join Date
    Nov 2004
    South Armagh, Ireland
    Posts
    12,884
    Quote Originally Posted by SteveJ View Post
    Try here
    There are two opinions of the GS. There are those who have ridden one who think its fantastic and there are those who haven't who know its crap.
  4. #100
    Join Date
    Mar 2010
    Posts
    39
    Nice one
    Not too expensive either
    Cheers, Aidan
  5. #101
    Join Date
    Jul 2004
    Posts
    1,060
    I did the right hand switch 3 months ago. Switch very sensitive with little tactile force to set it off.
  6. #102
    Join Date
    Jul 2016
    West Yorkshire
    Posts
    114
    If anyone's thinking of replacing a switch then make sure to order a couple. I managed to ruin one on my first attempt. Got there in the end though thanks to this thread.
  7. #103
    Join Date
    Jul 2004
    Posts
    1,060
    Diamond, when you fitted the new microswitch into the original white housing, sealed it and returned it back in the switchgear harness, did it look a bit higher.
    I had to remove some of the plastic node on the orange lever as it was permanently engaged. Also, the switch has no tactile feeling when pressing the indicator on.
  8. #104
    Join Date
    Apr 2009
    Coming to a scene near you......, UK
    Posts
    2,308
    Don't know if it helps but when I bought some replacement switches for my '05 12GS, it was possible to buy switches with different 'push' strengths, all the same size
  9. #105
    Join Date
    Jul 2016
    West Yorkshire
    Posts
    114
    Quote Originally Posted by Rugged Path View Post
    Once changed the switch definitely sits higher, enough that the indicator needs only a light touch to activate it.
    Wanted to gauge whether it might 'bed in' before shaving some off of the rear of the indicator button, although it's improved a little I think the button mod will be required.
    The action of the switch seems far softer than the OEM one with almost no tactile 'click' much the same as yours which can be a little disconcerting but I'm gradually getting used to it.
  10. #106
    Join Date
    Jul 2016
    West Yorkshire
    Posts
    114
    Quote Originally Posted by Popell View Post
    I used the above Ebay link to order mine, they only come in one type.
    Do you happen to have a link to the site where you ordered yours?
  11. #107
    Join Date
    Jul 2016
    West Yorkshire
    Posts
    114
    Interesting tip for those of you (like myself) with non ESA bikes. BMW very kindly included an ESA switch under the blanked out space where the button would have been so you'll not need to buy a switch.
    Alas I didn't check first.....
  12. #108
    Join Date
    Apr 2009
    Posts
    2,308
    Quote Originally Posted by Diamond GSer View Post
    Diamond, found some info, I bought them from Digikey in the states, ended up buying 10 off on the basis that I would melt a few with crap soldering technique. I had a few left which someone on here bought perhaps 2 years back.
    and a spec sheet for the switched that show different push force values
Posting Permissions
  • You may not post replies
  • You may not edit your posts
