Hi,
The Zumo is on order and I'm now looking to see if I have the correct leads etc. I have a new-ish Active-Plus Autocom, do I really need the £38 lead from Autocom? What's wrong with doing the following:-
Connect stereo music Zumo out put to Autocom Aux 2 (usual music input)
Connect Zumo mike socket(a mono jack) to either Aux1 (but that will need a stereo jack with tip & sleeve only connected) or straight into Aux 3.
Is it true that the Autocom lead does not deliver true stereo but combines L & R to both ears? This seems pretty crap, if true, and definitely not worth £38.
Seems to me that buying the GPS is like opening your wallet to all the suppliers of leads, mounts and bits & bobs that should be quite cheap but are NOT.
