Johnny Dangerously
Ok, as so many of you have been kind enough to offer my advice on GPS and wiring in the past, I thought its about time I gave a little back. Today I tested out wiring the Zumo to the GPS accesory socket at the headstock, and thoguht I would post some picture of my effort to help anyone else that might be trying. I've still not been able to find any step by step pictures on t'inernet, only after pictures, so though I'd fill the gap.
As a background, I intend buying the BMw accesory socket to plug this in the future, but its going to take my local dealer about a month to get it for me. In the mean time, I want to test this socket out before my trip to the alps in august and see if there are any issues with it.
So here goes
Step 1:
The GPS socket is fairly easy to spot when looking down from the side of the tank. it has a black cap on it and is secured in pretty tight to the other cabling. To remove the cap, you need to 'unhitch' the catch on it and pull it off. I found the easiest way to to this was with a small watchmakers screwdriver. From there I pushed the black (ground) wire from the zumo lead into port 1 (ground) of the GPS socket. I then did the same with the red (live) wire from the zumo lead into port 3 (live) of the GPS socket. Note port two on the gps socket is 'speed pulse' and isn't used.
next picture shows a longer range view of the socket to help locate (note zumo wires hanging over side of tank panels):
Step 2:
punched a couple of small holes in the cap to feed the cables through. I did this using thin nail (is that a pin?) and a hammer. Dead easy. Tried to judge the distance from the edge of the actual socket so the wires would go into the socket fairly straight without any pinching:
Step 3:
Hooked up the cradle and cable onto the dash to test out the wiring, and lo and behold it worked like a treat. Ignition on, the unit powers up and runs as normal. Ignition off, and the unit stay on from about 30 seconds before prompting to use battery or switch off.
Ignition on:
Ignition off:
Next Steps:
I'm going to use some silicon sealant on the top of the cap to keep it watertight and prevent the wires from pulling out. this can be seen below and is pretty cheap from maplin. I'm going to road test it then to see if it runs into any problems with vibration etc. Eventualy I'll then replace it with the BMW plug.
Silicon glue:
hope that helps.
So here goes
Step 1:
Step 2:
Step 3:
Ignition on:
Ignition off:
Next Steps:
Silicon glue:
hope that helps.
