I turn the ignition key to on, then press the ABS button down and hold for about 3-4 seconds. You know you have done it right when the ABS light continuously flashes slowly. As long as the ignition key stays on it will stay in that state. You can kill the engine by stalling or using the kill switch and that saves you going through the whole routine every time if you are stopping and starting.
