The standard gs11 headlight adjuster isnt very practical as you have to use a 6mm wrench to alter it
This is a little modification i made for mine , n it works a treat.
a pick of the adjuster mod
drill out midle hole on knurled spacer
tap out hole to 5mm to fit adjuster
drill out n tap side of wheel n fit a grub screw
finnished peice.
to adjust it ,its the same as ye standard oe adjuster ,but it has the advantage of a great fuggin wheel to grab even wi ye gloves on.
finnished peice.
