elefantmanshawn
That GS almost looks as good as a GSA,must have cost a fortune to do.
Excuse my ignorance or if I have not read correctly, what do the winglets actually do?
HI
Aquired a set of winglets to fit, found no support brackets on GS ,
( Its pre 2008 that'll teach me to look first ) , has anyone any experience of fitting them directly to fairing ? I presume the fairing will need to be strengthened ?? If so any ideas??
Has anybody dropped the bike with winglets fitted on a GS? I take it they would just snap off and not damage anything else - they seem to stick out quite far...
Thanks info and heads up - brilliant thread.
My 09 SE fitted with nippy normans winglets - took about 20 mins - best advice from thread (ignore the supplied template ). used a small Dremel type drill to mark the holes coming up over using the alread pre-drilled holes as guide . Enlarge holes to 6.5 mm from above . No need to remove anything.
Dave
Yes I have !!!! And yes they do snap and break but no other damage !
