I see that BuMW have tidied up the wire cabling though...
fitted hard flexible sleeving & plug shrouds since deletion of the big slotted cover by the look of it.
This problem has been posted many times along with the side stand switch problem.
It seems odd that no one has marketed a bypass lead for either.
Does anyone know where to get the relevant plugs from?
Simple question: Should there be a gasket with it, or is it truly a separate part?
Yes Wapping, I got mine about 4 weeks ago from a dealer and there was a gasket mounted on the unit in the box!
Ok ... been a while .. some information .. on teh can buss petrol controller as I understand it?
The switch is just that - off or on .. in eitehr position (or state) it dissapates little power. But it can operate very fast - so the pump can be controlled ..
The electronics does not controll the fuel pressure .. no sensor so no control .. must be a regulator somewheres.
The can buss EFI system knows about how much fuel the bike is consuming so can vary the pumps output to keep over the required supply. This keeps the fuel pressure happy .. and reduces the power required to the pump .. and keeps the fuel from gettins so hot ..
many fuel injection systems just pump the same fuel round and round a circuit with the injectors taking what they need.
that's why it switches to 80%, it's not supplying direct to the injector.
I think I might just contact BuMW and ask them....
So in light of my up and coming euro trip he has kindly donated his old controller so it's plug will be accompanying me 'just in case' as they say. Be prepared, dib dib and all that.
