TimC1
After long deliberations I finally decided to buy a Caberg Justissimo GT Helmet and a Justspeak Bluetooth headset kit, searching through the net I decided to purchase from Lings who were offering free delivery. I ordered the helmet and headset as separate items but if you phone them on 01379 851091 I believe they will fit it in the helmet for you. Fitting the headset took about 20 Minutes and was quite simple after reading the instructions, the fiddliest bit being the connection of the ribbon cable from the buttons to the electronic module, there being no way to tell which way round it should go.
The next job was to turn it on and pair it with my TomTom Rider 1 GPS, One of the reasons I took so long to buy a Bluetooth helmet was because I could not find out with any certainty whether it would work with a GPS in fact the instructions that came with the Justspeak set do not make any mention of GPS at all, it lists Pairing with phones, with another helmet and with an MP3 reader (?) but not GPS. Deciphering the menus for the two buttons on the side of the helmet took a while, but eventually I worked out that you Press and hold the down button for about 4 seconds to turn the unit on and holding the button down for a further 7 seconds will put it in pairing mode. The first attempt failed, the second attempt showed the headset on the TomTom screen but failed to connect, third time it worked. I then turned on my phone and using the GPS to dial the number I made a phone call to try it out and it worked fine with plenty of volume (LOUD).
Today is the first chance to try it out on the road. Initially I had a problem connecting it to the GPS but then I realised that I had paired it to my phone the other night when I thought I might be going out locally without the GPS, by deleting the pairing in my phone everything connected up without any more problems. Because it’s a new helmet and quite tight I started off without any earplugs on my 1100 GS with the standard screen it was quite noisy, for the return journey I put in earplugs and it was actually quite comfortable and quiet, the headset volume was set at 65% and was very clear.
Overall I’m very pleased with my purchase its comfortable, quiet (with earplugs) and it works without any phaphing about with cables.
http://www.lings.com/lingscentralAp...205154d69745&gclid=CNWU-6iC95MCFQHklAod8BKIVg
