"External" 12V battery connection
MiGSel
Belgium
As seen on an R1150GS somewhere:
a +12V connector with a rubber cap, that you can use to hook a jumper cable.
Where are they from?
Does anybody know of a reseller?
Cheers,
Michel
Remote starting
See the NN's socket what anout a plug to go with it. Aventures just have an extendedd bolt on the starter trerm one jump lead on here and one on the frammw hjkob done, no need for special leads and plugs which no one will have, the afore mentiond just requires crocadile clips as fitted to all jump leads.!. the KISS principle from amature radio, "keep it simple stupid".
Dave gs. (very simple)
Jump lugs
I have an 02 1150 and fitted one of these plus a negative one to the rear of the cylinder. Got both bits from BMW, can't remember how much now but it was only a few quid.
The positive bracket bolts straight onto the starter feed from the battery, and needs a small hole drilling in the plastic cover. Took about 20 mins. I ended up with 2 types of brackets for the starter one of which fitted, s'easy and nice to know you can get going easy if you have battery problems.
Cheers,
Michel
It's a genuine BMW part - and not very expensive :thumb
