The dips in the graph aren't fueling related, so couldn't get rid of them. You don't really notice them on the road.
Only a numpty would put on a wholly different exhaust without carefully considering the tune. That said . . . .
Did you get a dual map - i.e. a map for each cylinder or just a single one?
I got a dual map. I was shocked at how lean the GSA was at certain revs. The map shows having to add 26% fuel at some points but also taking away 10% due to over fuelling in others.
I was not chasing power just the fuelling being better. I think the 08's are worse than the older ones for fuelling and the tech guy said it is the worst 1200 boxer he has seen for lean running.
It is a different bike now.
Prop
yes it looks like the company tries to meet EURO 5 specs actually....
So a question for those who have gone through this route. Was it because you found the bike ran rough or was it because you're actually that kind of person,: a tinkerer/perfectionist type who just has to have everything completely sprted.
Not being judgemental here (I've had wheels powdercoated etc just to make me happy), I'm just curious.
Interestingly, my bike (with the "old" less powerful engine) makes the same power on the dyno as the 08s shown in this thread (with a PC III, filter, and full system). Makes you wonder about BMWs claimed HP increase for the 08 model year doesn't it?
I've had one recently fitted to my 07 and am very happy with the results. First time I've ever put one on a bike despite many years of sportsbikes and track days.
The bike used to hesitate slightly when given a big handful of gas, such as for enthusiastic overtakes, then go like a rocket once it had a little "think". Almost like a mild version of the sensation you get when traction control kicks in on a car
The PC III has totally cured this, and made the bike much more responsive and willing throughout the rev range. I didn't feel there was anything wrong before (other than th high end hesitance) but was pleasantly surprised by the improvement everywhere.
Not much of a power increase (it already had a full Remus system fitted before it went in) but improved fueling throughout.
Read this from Bridgestone
Dynamometer Tests
Dyno runs place extreme, localised stresses on motorcycle tyres, sometimes causing invisible internal damage to the tyre’s construction. It is possible that this damage may lead to tyre failure at some point. Never use a tyre for street, track day or off-road use that has been used on a dyno. If a dyno run is to be made we advise that a tyre due to be discarded should be used, and then removed from the bike immediately following the dyno run.
Interested if anybody who has done the dyno runs bothers with this advise.
I have fitted a Power Commander to mine, an 08 GSA. Really pleased with it. Vast improvements through out the rev range, just nice to ride, mid range grunt is fantastic. I bought it from Dynojet UK, they retail about £270, but they fitted mine and spent about 3 hours with it on the dyno creating a map which they will put on there website for downloading. Bike spec is K&N filter, Remus headers with std can.
Well worth the money.
Prop
I did exactly as Peter describes, there's some info and installation 'photo story' here although I've still to write the installation notes:For those of you that have fitted the PC and seen improvements, did you disconnect the O2 sensors, or leave them connected?
If you disconnected them, what, if anything, did you do to tidy the open connectors ?
Wot!!??.......I'd be interested to see this for myself, linky please!Read this from Bridgestone
Dynamometer Tests
He was a jammy bugger if that included Dyno time.......I asked around/posted here and £100 for dyno runs/PCIII set up is the minimum to expect, I paid £120 at JHS Racing in Bristol. Make sure you look for someone with the latest Dyno equipment and Dynojet Power Commander 'acreditation' (check their website;-)Hi Prop
I would be interested in having this done too but have a full laser system with no cat and std filter so would presumably need a new custom map. Did the £270 inc the dyno and mapping and where was the dyno facility?
If anyone else has good first hand knowledge of PC fitters and dyno facilites I would be interested.
Harry
I did just as Peter has already said and he's spot on re having to disconnect the Lambda (O2) sensors. Some info and installation 'photo story' here (I've still to write the installation notes ):For those of you that have fitted the PC and seen improvements, did you disconnect the O2 sensors, or leave them connected?
