This thread is to show any electrical numpty can wire up a set of winker tail stop lights...
This isnt a new idea , ive copied it from another mates bike iv seen and , gathered information from mates that have done simalair..
The led's fit in the indicator pods , i used two in each, then feed the extended wire through the indicator stalk , up under the back mudguard into the rear light unit , for red (power) lead , and up under and through to the rhs bolt that holds ye rear rack on under the tool box this is your Earth point
step one...
acquire a pack of red 12v leds , mine was donated from a good lad of this site (cheers mike)
step two
get some 2mm wire to extend the leds , i used an old satnav power lead and stripped out the black and red wires
step three
join and solder the red wires together for each led , to make four into two wires
step four
join and solder the black wires together for each led also to make four wires into two wires
step five
extend each led set by soldering a long length of red wire to red power lead and black wire to black Earth lead
remember to fit your shrink wrap before soldering wires together to get a good fitting
you now should have two sets of four leds soldered to a long extention wire
your leds should look like this
continued...
step one...
step two
step three
step four
step five
continued...
