***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 49 to 64 of 67
Thread: Switched power - The easy way
  1. #49
    Join Date
    Sep 2008
    Ardee, Co. Louth
    Posts
    2,686
    Switched Power the Easy-way
    sorry couldn't resist
  2. #50
    New Member (less than 15 Posts)
    Join Date
    Sep 2012
    Berkshire
    Posts
    7
    Can confirm the timings after a little experimentation.
    And also splitter cable 61 13 2 316 621 fitted my 2007 GS. Interestingly it doesn't seem to be listed as a GS part, but works a treat, and makes my autocom easily demountable.
  3. #51
    Join Date
    Jul 2013
    Kidderminster
    Posts
    6
    Great info guys, made fitting my intercom very easy. Thanks
  4. #52
    Member
    Join Date
    Jan 2014
    Penrith, Cumbria, United Kingdom
    Posts
    42
    Numpty with technical gear
    Quote Originally Posted by Wapping View Post
    Here is the Baron's lead in all its glory.
    He tells me the lead is over a meter long....
    The sockets look totally different, too.
    Any chance of a picture of socket under the seat, I can't seem to find it on mine. Thanks, and great tip!
  5. #53
    Join Date
    Oct 2005
    Wapping, London
    Posts
    46,819
    Which bike do you own and where, under the seat, are you looking?
  6. #54
    Join Date
    Apr 2012
    Essex
    Posts
    263
    Can you buy the splitter plug on its own ??? as I may be looking for one for my 2011 twin cam, is this correct number from my bike 61 12 7 712 581
    Dave
  7. #55
    Member
    Join Date
    Mar 2014
    Pembrokeshire, Wales
    Posts
    93
    Looking at adding a PDM60 to my 2014 GSA when it arrives.where is the most suitable place to trigger the PDM60 from using a switched live? Looking at having PDM under seat with autocom. Thank you.
  8. #56
    Join Date
    Oct 2005
    Wapping, London
    Posts
    46,819
    Any switched power supply will do, for instance the rear light feed.
    If you wanted to avoid chopping into any wires, have a look at this: http://www.twistedthrottle.com/elect...ph-motorcycles
    It really is plug-and-play; nicely made, too.
  9. #57
    Join Date
    Dec 2007
    Southampton, England
    Posts
    2,451
    Not sure the rear light feed will trigger the PDM60.
    My understanding is that the rear light feed is not 12v but I could be wrong.
    There is a suitably place trigger source just behind the tank which is approx 50mm from where the PDM60 can be sited.
  10. #58
    Join Date
    Oct 2005
    Wapping, London
    Posts
    46,819
    I am not sure that the trigger needs to be 12 volts. The trigger only requires a positive voltage signal, nothing more.
    It's current draw is minimal, less tan 1/1000 of an amp. I think just about anything will do it.
    Bods seem to use all sorts of triggers, amongst the most popular seems to be a feed from the diagnostic hub. A search of 'PDM 60 trigger' turns up loads of suggestions.
  11. #59
    Member
    Join Date
    Mar 2014
    Posts
    93
    Thanks all for replies.
  12. #60
    Moderator
    Join Date
    Jun 2007
    Glenshee
    Posts
    6,355
    I used the feed to the aux socket left side under seat to trigger my PDM 60. Easy peasy.
  13. #61
    Member
    Join Date
    Mar 2014
    Posts
    93
    I used the advice below. All fitted now Autocom coming and jacket heating SWMBO.
    http://advrider.com/forums/showthread.php?t=928394
  14. #62
    Join Date
    Oct 2012
    In a Remote area apparently.
    Posts
    4,409
    I have read this post with interest, having had problems with a USB lead I had connected through my Centec fuse panel. Although it took me a while to discover that said USB lead draws power even when not in use and was, over a couple of weeks killing the battery. So I have now purchased the lead part no, 61 12 7 712 581 and im going to fit a relay between the battery and fuse panel to make the whole panel switched. This should cure the problem. Ta for the info peeps. Del
  15. #63
    Join Date
    Oct 2005
    Wapping, London
    Posts
    46,819
    A lot of devices and / or leads draw power, even when 'off' particularly when they are not off at all but in 'sleep' mode.
    A properly switched supply or a relay will sort it out.
  16. #64
    Join Date
    Oct 2012
    Posts
    4,409
    Click here to find out how to remove these ads
    Yup, I found that out the hard way and blamed the battery for the problem and it wasn't. OK I have had to pay £29 for a proper lead but its plug and play with no cutting of the harness. Ta, Del
Posting Permissions
  • You may not post replies
  • You may not edit your posts
