Nippy Normans supply Touratech, Wunderlich and many other makes of accessories.
Page 1 of 7 123 ... LastLast
Results 1 to 16 of 109
Thread: 04/05 Flange defect, take note
  1. #1
    michnus
    If you own a 04 1200GS, go check the flange on your bike, might be 04 and 05 models, just possibly be one of the flanges that will have cracks on the lugs securing the rear brake disc to the flange.
    On my 04 1200, the flange which secures the rear wheel and rear brake disc some how got some cracks on all the lugs securing the rear brake disc. It is not a common problem and from the things of it seems to be 04 specific, not confirmed. It is suspected that it is either a design fault or metal fatigue.
    This is a safety critical item and on a bike like this must never happen. You need to take of the rear wheel and inspect the flange properly. If you intent buying a 1200GS/GSA let the seller/ dealer take off the rear wheel and confirm it does not have cracks on the lugs as this item will cost you around $280 to replace.
  2. #2
    Senior Member
    Join Date
    Jun 2008
    Wales
    Posts
    150
    Nowt worse than cracked flange.
  3. #3
    Senior Member
    Join Date
    Dec 2006
    South Cheshire, England
    Posts
    615
    My back wheel comes off when the new FD oil arrives. I'll have a good look. Thanks for the warning.
  4. #4
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    11,658
    I recently fitted a new wavy rear disk to my '04 and didn't notice any cracks/defects with the carrier but will remove my rear wheel in the morning and inspect it more closely.
    Thanks for the heads up.
    ADAM
    2008 R1200GSA
    2011 Yamaha Tmax
  5. #5
    Senior Member
    Join Date
    Jun 2004
    Cumberland
    Posts
    2,901
    I`ve just checked mine and it`s ok Mines a 54 plate with 18k. If you have alloy wheels you can check them without having to take the back wheel off not sure about the spoked ones
  6. #6
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    11,658
    THANKS VERY MUCH
    Michnus,
    a very big THANK YOU.
    Just went out to check my '04 bike. The three 'arms' I could see easily on my rear brake disk/wheel bub were fine (as I expected). Turned the wheel and to my horror, the other two arms have the cracks.
    When I recently changed my rear disk due to warping with a tight spot, I did a cursory glance rather than a proper good eyeball. I'm normally a stickler for all things engineering, can't believe I didn't find this earlier (unless its only just occurred).
    In hindsight, it may have been the cracked brake disk hub that allowed the disk to warp?
    Either way, I'm off to Bahnstormer Motorrad this afternoon on a rideout so will ask them about possible goodwill or discount on a replacement hub. This is not good on a component which is meant to stay together for the life of the bike, and its failure could have potentially life-threatening consequences.
    ADAM
    2008 R1200GSA
    2011 Yamaha Tmax
  7. #7
    Senior Member
    Join Date
    Aug 2003
    Chicago IL. USA
    Posts
    468
    As reported on another site...the cause is from "Over Torqued" wheel bolts/lugs.
    Use a Torque Wrench!!!!
  8. #8
    Stay Frosty Click here to find out how to Subscribe
    Join Date
    Aug 2002
    Dorset
    Posts
    27,735
    Quote Originally Posted by bmwrich58 View Post
    that doesn't seem likely. cracks come from the disc mounting holes, and are nowhere near the wheel mount bolts.
    does this only affect early models or do i have to take my 06 wheel off?
  9. #9
    Join Date
    Dec 2004
    Huntingdonshire (Cambridgeshire) & Bedfordshire
    Posts
    14,333
    Just been outside to check my flange.
    No cracks apparent on either the brake disk mounting lugs, or as far as I can see, without removing the wheel, no cracks adjacent to the wheel mounting holes.
    2005 GS 37,000 miles.
  10. #10
    Join Date
    Dec 2004
    Posts
    14,333
    Quote Originally Posted by Pukmeister View Post
    Michnus,
    Maybe you cracked it when you changed the disk????????????????
  11. #11
    michnus
    I did try and read up as much as possible on this, and the general feeling is that it is NOT from over tightening, for one, my brake disc has never been removed from the bike since new. It's either a design fault or material grade.
    Some more reading, some metal guru's also posted some opinions.
    http://www.wilddog.za.net/forum/index.php?topic=29818.0
    http://www.advrider.com/forums/showt...ghlight=flange
  12. #12
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    11,658
    Quote Originally Posted by Engineer View Post
    Perhaps, but I'm pretty sure I would have noticed it. My guess is brittle fracture but as I don't have access to a scanning electron microscope I can't prove it. The profile of the component has no obvious stress raisers and the two cracks have propagated along differing paths.
    BMWRich58, I've been an Engineering Technician since 1982. I've worked on Gas Turbines and reciprocating diesels the size of a house and costing millions. I think I can be trusted to safely tighten a fastener or two on a motorbike. Of course I used a torque wrench and followed the instructions in the RepRom, I'm not stupid.
    My local dealer has never seen/heard of this happening and took a look out of interest. Eyebrows were raised as the same flange is fitted to the entire R1200 range plus the K1200 model range. They asked if Michnus's bike had the stock disk and pads as mine are non-OEM.
    They advised me to contact BMW customer services as a goodwill gesture is unlikely. I simply bit the bullet and ordered a replacement 'flange' under the new part number of C33.11.7.699.631 for £115.99+vat (£133.38) as the old part is no longer available ( I wonder why??).
    Pity really as I am unemployed again at present so could do without the (unexpected) expense but my bike is my sole means of transport. No doubt pulling the flange from the splined rear hub will cause me some more headaches. Probably gonna need to put the FD in the freezer for a bit, then get the turbotorch out.
    ADAM
    2008 R1200GSA
    2011 Yamaha Tmax
  13. #13
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    11,658
    Quote Originally Posted by cookie View Post
    Does this only affect early models or do I have to take my 06 wheel off?
    Just checked out other bikes on Bahnstormers forecourt today. They were all newer so had no cracking (yet )
    If you have cast alloy wheels the brake disk mounting lugs on the flange can be seen easily through the wheel without the need to remove it.
    On spoked wheeled bikes, the central wheel bub is a larger diameter and hides them so you need to remove the wheel to check the flange lugs for cracking.
    ADAM
    2008 R1200GSA
    2011 Yamaha Tmax
  14. #14
    Senior Member
    Join Date
    Jun 2008
    Wales
    Posts
    150
    It's got tapped holes in it, if they're not stress raiser i don't know what is?
    That said if we are ruling out over / under torquing, uneven tightening patterns and everything was flat - true and clean prior to assembly then it is a disturbing failure.
  15. #15
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    11,658
    Quote Originally Posted by MartinL View Post
    Fair one, but as the tapped holes are unavoidable by design function I didn't mention them. I was referring to the shape of the component having smooth radii and a good surface finish.
    It has certainly disturbed me to the tune of £133 on a component you would expect to be slightly over-engineered.
    ADAM
    2008 R1200GSA
    2011 Yamaha Tmax
  16. #16
    Senior Member
    Join Date
    Jul 2005
    Poole, England
    Posts
    187
    It makes sense for BWM to try and blame over torquing ove the bolts. That way its the customer's fault and they don't have to pay any goodwill.
    Thanks for the heads up. Will have a look at mine tonight.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
