fancy a go when its finished then?
Sounds like you have some fond memories there matey.
Im fortunate in that im tall and ... heavy... helps starting
Can start it first kick now everytime. Even in trainers! (though that was a bit scary the first time)
Road registered frames in powdercoating at the minute. Should be finished early next week.
Managed to source another crf front end as this one is doing my head in, trying to find a bloody caliper carrier is a nightmare. Cheapest i found was £40!!!! got a complete other front end, forks, yokes, wheel, caliper, master cylinder, and rear wheel for £250
So the spare set can go in my xtz750 rallye project.
Wiring loom is coming together, Service honda have stopped production of their 200watt stator kit unfortunately whilst its redesigned so im going to run the lights off a 5000 mah lithium battery pack i have lying around. It should give a couple of hours use for the HID headlight and all the bulbs. Which will always be plenty enough to get me home if it gets dark.
Have to use a special charger for the lithium cells though.
Also need to modify the magura hydraulic clutch to fit the cr's case's. Have found some rather sexy looking ignition and clutch covers out of cnc'd aluminum... i think it deserves it
Also the clutch will then hold an extra 100cc's of oil which should help increase its life.
They will also look cool, the ignition ones as standard are some 'orrible nylon jobbie and the clutch ones all scuffed and looks cack.
