Bill - i cant get it to workIn theory, you can wrap it in the html tags for 'blink' which are <bl ink> at the front and close it with </b link> at the end...without the spaces of course (they wouldn't show up as text if I'd left them out)
<blink>BLINK</blink>
The recipient will have to have their options set to show htm coding, or it won't work.
I haven't tried it though, so it may not work....send yourself one to test it
EDIT.....leaving the spaces dint work...hit the quote button as if you were going to quote this post in a reply and you'll see the code in the quoted text though
Bill - I dont have any animation effect options
Ok, try this instead....
1. Select the text that you want to animate.
2. Choose Format a Font (or right-click the selected text and choose
Font). The Font dialog box appears.
3. Click the Text Effects tab.
The Text Effects page of the Font dialog box appears, including a
list of animation effects.
4. Choose an animation effect, such as Sparkle Text.
A sample of the animation effect appears at the bottom of the dialog
box.
5. Click OK.
Cut n pasted from an article, so again, I haven't tried it 'cos I use Gmail on Firefox...
This is correct.......if you can't do it in Outlook, do it in MS Word and copy and paste it into your email......it works because I just tried it.
Note - in my Outlook, Tools / Options / Mail Format, Message Format is set to 'HTML'.
Not that I'd ever use it - it is likely that your recipient will receive your email in 'plain text' or some other format and they may lose your initial formatting.
