Vendome 41
Has any one used one of them on long distance rathe than off road ?
Would appriciate any comments
jon b said:when the time comes to replace your bladder(in your hydration pack) the PLATYPUS bladders are a lot better than camelback ones.You dont get that taste of plastic that you do with the camelback bladders,stronger too
Burgman said:
'Old Berber' tale - First sign of dehydration is bad temper - always works.
Mike O said:Good call - I found myself getting irritable in the desert in Utah on a couple of occasions and couldn't work out why - started drinking more (I use a CamelBack 2l, BTW) and the problem disappeared...
Mike
jefformston said:I'd have said the other way around, Camelbak bladders are stronger than the Platypus ones. Certainly when I did the Caledonian Challenge we were recommended to buy Cambak for their strength.
