Nippy Normans supply Touratech, Wunderlich and many other makes of accessories.
Page 1 of 2 12 LastLast
Results 1 to 16 of 19
Thread: Front tyre problem?
  1. #1
    Member
    Join Date
    Dec 2008
    Normandie France
    Posts
    46
    Front tyre problem?
    Having gotten used to strange wear patterns on front tyres, usually leading edge of each block wears more than trailing edge etc, I am puzzled by the current effect. The blebs are about the size of a pound coin and repeat every second tread block right round the tyre. The fine groove that can be seen also extends right round and appears to be connected in some way to the blebs.
    Question is, is this a defect, is it safe to continue using, or am I unduly worried. Tyre is Annakee 2 with about 6-7K on it.
    Hope the photos appear, this is my first attempt at an upload.
    Attached Images Attached Images
  2. #2
    Registered User
    Join Date
    Aug 2006
    birmingham
    Posts
    583
    Are the lumpy bits soft in the sense they can be pushed down with your fingers? They look a bit like raised blisters indicating the tread is delaminating from the carcass....
    If they are as hard as the tread block next to them, well I've no idea. Bizarre.
  3. #3
    Senior Member
    Join Date
    Oct 2009
    e.g London, England
    Posts
    402
    I'll go check my front tyre (about same mileage I think...) and see if it's also doing that.
    If so I'll post a pic.
  4. #4
    Senior Member
    Join Date
    Sep 2007
    pontefract
    Posts
    5,723
    i think id be getting in touch with the manufacturer bout that, looks like a manufacturing fault,
    dont mess with tyres,,
    the lines running round the tyres too. they look odd, like de lamination,like rickG says
  5. #5
    Senior Member
    Join Date
    Oct 2009
    e.g London, England
    Posts
    402
    Strange thing, my front tyre (Michelin Anakee TL, approx. 9.000miles) also shows those weird shapes, not as obvious as you but noticeable nonetheless...
  6. #6
    Member
    Join Date
    Dec 2008
    Normandie France
    Posts
    46
    Quote Originally Posted by RickG View Post
    Just checked. Blebs are as hard as the rest of the tyre. I thought that it could be due to uneven braking but have had no problems in that area since discs replaced at 6K by dealer, no pulsing at handlebar at any speed.
    I did think it could be due to ABS kicking in as we have a lot of gravelly roads around here and it is not unusual for ABS to activate.
  7. #7
    Member
    Join Date
    Dec 2008
    Normandie France
    Posts
    46
    Quote Originally Posted by London Mole View Post
    Thanks for the photos. My blebs are on the left side only, when viewed from the saddle, which could indicate an effect by the camber (here in France) which is usually steeper that uk on country lanes.
    Your blebs seem to cover adjecent blocks left to right. Do they repeat around the tyre like mine?
  8. #8
    Registered User
    Join Date
    Aug 2006
    birmingham
    Posts
    583
    Are your tyre pressures OK? If they were too low on the front, the combination of tyre deformation and the block pattern may give rise to something odd like you are seeing. Check your own gauge against another as they can be quite inaccuarte. Check the tyre manufacturers recommendation for pressure as this may be different from that in the BM handbook.
    If you don't need dual purpose tyres try a road only option next time, they are loads better in my opinion and don't suffer so badly from uneven block wear.
  9. #9
    Senior Member
    Join Date
    Jun 2008
    warrington
    Posts
    306
    Problem with the tyre, take it to your fitter they should sort you out. Although after 6000mls and the wear on it you should be entittled to a small pecentage back.
    Just going off the picture though.
    Dave
  10. #10
    Senior Member
    Join Date
    Oct 2009
    e.g London, England
    Posts
    402
    Quote Originally Posted by Gatesy View Post
    Yes they are all around the tyre, even the few which are not raised a lot are visible as they show more tiny cuts than the rest of the tyre...
  11. #11
    Join Date
    Oct 2005
    Wapping, London
    Posts
    48,998
    Call Michelin.
    Campbell Road Tel: 017 82401853
    Stoke-on-Trent
    ST4 4EY
    They are very helpful on the phone.
    They will tell you, without a doubt.
  12. #12
    Member
    Join Date
    Dec 2008
    Normandie France
    Posts
    46
    Quote Originally Posted by Wapping View Post
    Call Michelin.
    Stoke-on-Trent
    ST4 4EY
    Took your advice, the people at Michelin were only too pleased to try and help and after 2 days I received the following reply;
    Please see comments below from our inspection dept.
    "Looking at the photos we cannot say for sure if the damage is a wear problem or something else.
    We would not advise from a photograph that the customer continues to use the tyre and would advise the tyre be returned to Q/TB so we can give a definite answer."
    Sort of what I expected really as a visual inspection is the only valid method of deciding on what is after all a safety issue.
    Many thanks to all who responded to my query, some with photos. Based on the response from GSers I think I will continue to use the tyre and monitor it closely for any signs of deterioration.
  13. #13
    Join Date
    Oct 2005
    Wapping, London
    Posts
    48,998
    Excellent
    So you get a prompt reply from Michelin and advised not to use it / return it to them..... and then decide to follow the advice from UKGSer.... you could have decided that yourself without any third party input, surely?
    Penny to a pound says Michelin will refund the cost of a new tyre while it is returned to them. But by all means monitor away......
  14. #14
    Senior Member
    Join Date
    Dec 2008
    Land
    Posts
    1,177
    Yeah.... but what do Michelin know about tyres? eh... ?? eh??
  15. #15
    Shep of the Dessert Click here to find out how to Subscribe
    Join Date
    Nov 2004
    Lleyn Penninsular
    Posts
    12,555
    No way would I still ride on that front tyre, i'll guess you've never had a front tyre puncture whilst riding? It's very scarey and all thoughts are very focussed on not dieing under the wheels of the next truck that comes along!
    Dont be so tight
  16. #16
    Join Date
    Oct 2004
    northern ireland
    Posts
    2,104
    You silly boy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
"Its about being a grown up hooligan - and if that means a dark visor, remus open pipe and a bit of speeding out of town then all well and good" Kaister 2005
"I have always known this community is full good people even if most of you cover it up with piss n vinegar" Chad 2018
