I have just bought a
Shark Evoline Series 2 and what a cracking bit of kit
with the finish being right up there with my
Shoei Hornet DS and the fit perfect
(I am an XL in both Shoei and Arai and the XL Evoline fit is just spot_on). The flip works a damned sight better than the flip on my old
Schuberth C3 and the ability to rotate the chinbar to the back of the helmet is priceless. It is beautifully engineered and the chinbar integrates perfectly in balance and aesthetically giving a true open helmet appearance and feel.
The visor has 9 well positioned indents which really do work and the inbuilt sunscreen comes right down to the bridge of the nose giving super eye protection. The neck-strap is of the
'ski-boot ratchet' variety and works simply but well and is also a doddle to undo with a gloved hand. Finally, the field-of-view is huge and 'lifesavers' are not a chore.
There is a great selection of colours and designs and you can pick one up for £250 or so. What a winner.
Something's not right with
Shark helmets.
Here's the problem. In spite of some initial doubts, I succimbed to the
'must try' bug and bought a
Shark Evoline Series 2 in a stunning titanium gray. It cost me £267 delivered which is a lot, lot cheaper than the equivalent
Shoei or S
chuberth. Being a standard XL in the better known helmets, I took a chance on sizing and ordered and XL - being the biggest that
Shark make in this model.
The helmet arrived and careful inspection showed that it gave away nothing in quality and finish to the other two more expensive pair. So I raised the chinbar and tried it on. Perfect around the head and ears - firm but very, very comfortable with a natty bayonet strap which is really easy to use.
Next to drop the chinbar and see if there was enough room for my big chin - just to point out that the
Schuberth C3 has a lot of room but
the Shoei Multitec butts hard against my chin. Wonder of wonders, the
Evoline was perfect.
Now for a ride.
The
Evoline is as quiet as any helmet has a right to be and the ability to ride legally with the chinbar fully back and the sun visor down makes these hot summer days a real joy. All-in-all, I highly rate this helmet - in fact so much so that I wanted to buy another one with graphics. And that is where everything goes tits-up.
These helmets are in bloody short supply and, amongst the sparse stock distributors hold, the XL is even rarer in spite of what they may advertise. I eventually called the importer and located just one helmet in the right graphic and size at a Triumph dealership near Oxford. I give them a ring and the parts guy said, yes, they had what I wanted in stock and no, they wouldn't post it to me. When questioned, he answered that even were he to post the helmet to me, he wouldn't take it back for any reason. Well as I wanted it, I wasn't about to quote the
Consumer Protection Regulations 2000 and its seven day 'cooling-off' period so I drove to Oxford to collect it. And that turned out to be the good bit of luck and why something is not right with
Shark helmets.
I arrived at the counter and the guy pulled out the helmet, took it out and handed it to me. Right graphics? Check! Right size? Check! I tried it on to make sure and it seemed to be the same fit as my own. Then I closed the chinbar ..........and it bloody well wouldn't get past my chin.
Try as I might, it was a completely different size to the great-fitting one I have written about. I double checked the size - XL - looked inside, outside, tried it on again - nada, nothing, no-way was it the same chinbar. So I then tried on another
Evoline in Large in case the first had been mislabelled and that was just impossible and the shell was obviously too small.
Clearly there is a serious quality-control issue with
Shark as I suspect that a chinbar from a smaller helmet had been fitted to the XL shell. Crazy. So if you are tempted to buy one of these, don't do it mail-order but buy from a dealer direct. At least you will be sure of the sizing.
