There you go Kev, now just need to figure the rest out
OK, so I have been slacking a bit.
But then I did say I was going to try be patient.
Yesterday was Nicola's bithday, so after a cuppa tea in bed, some prezzies and a nice new helmet, we went over to Royal Tunbridge Wells for the day, shopping and being tourists.
Today I was going to paint the garage door frames that I did on Friday, their second coat, and also paint the outside of the garage, I am going from plain stark white to a softer Magnolia or cream colour, instead I ended up carting a load of wooden pallets and wood home fromt he neighbour 2 houses away, to chop up for the fire place, and also brought about 12 breeze blocks home for later use.
The other thing I did, and got caught on camera by Nicola for, was to hammer away at the stuck piston.....
Pics to follow.
I also took the exhaust off, and got the bike on its side to remove the rear brake pedal, and just started on the footpegs which have been WELDED onto the frame, when the neighbour came to ask if i wanted all the wood and bricks, which again distracted me.
Truely caught "Red Handed" by Nicola who heard the racket and came to inspect, camera at the ready.
This is how far I got with the strip down.
Piston down, and ports showing.
The barrel does not want to move from where it is, I also tried gently to remove the studs, failing there.
At this point I stopped with the bike and switched to "woodwork"
Hopefully I can figure out tomorrow what to do with the welded on, home made footpegs.
I suspect they will be staying there, as the damage may be irreversable.
