skywalker
That's why some have been to visit me and I have been to visit some of them, I am meeting up with a few of them next month as well.
Don't worry folks the men in white coats are on the way!!
Elaine Page & Barbara Dickson sang that
The problem isn't the final drives. It's the fact that GS's are ridden by fat bastids that load 300 kilos of camping gear on em for one night...
Could be something in that
Two F/D fails I'm aware of were both due to shall we say "Operator Error" 1st had a minor oil leak into the paralever, it was ignored and the drive oil topped up occasionally, inevitably a lengthy trip was undertaken the oil leak forgotten about until the drive ran dry and failed, all BMW's fault of course
2nd, the drive shaft was seized, it appeared to have been like that from new, eventually the increased shocking into the final drive caused the pinion bearing to fail, You could claim this was down to BMW as it appeared the shaft had been seized from new but good maintenance would have picked it long before the F/D failed at around 30K It is common to see seized drive shafts on 1100/1150, worth checking
What do you mean by seized drive shaft? Seems like something you wouldn't be able to ride with...
The drive shaft is in two parts, which are splined, it is designed to move, to shorten and lengthen as the F/D pivots on its pivot pins and general suspension movement, if seized somethings goto give and the shaft tends to ride over the front pinion spline clip or the gearbox out put spline clip or both, but this still increases the shocking to the drive or into the gearbox, it is best (IMO) to check you shaft is not seized, check on this site "Driveshaft seized"
Quite right sir. I've been in the motor trade for most of my working life and I've never seen a vehicle replaced. All the manufacturer has to do is repair the fault and anything else is goodwill. I've been on the end of customers demanding replacement vehicles for all sorts of things up to and including blown engines and we never replaced a vehicle despite all sorts of legal threats.
The drive shaft is in two parts, which are splined, .
The 1200 shaft is one piece
Personally I think its an oil quantity & design issue.
Think about the stuation re pinion bearing failure. Oil level quantity intially reduced to combat problem of oil leaking out of right hand seal. Intial cost to redesign rear axle with breather in it prohibative until next financial budget allows this. Low & behold from late 2010 we have a redesigned rear axle with breather in it. Rear disc carrier also redesigned. If it was Japanese this would have been sorted long ago.With a 180ml oil capacity without the crownwheel assembly in place the oil level comes up to the bottom of the right axle seal. Given the mass of the crownwheel assembly this still only gives the pinion bearing a semi splash feed. Scrimmenger's recommend 220ml.
The crownwheel bearing's undergone 3 part number changes which points to changes in spec. The bearing still lives outside the oil in the axle which leads to it living in a hostile environment despite preparatary measures which aren't sufficent.
The cost to redesign the whole axle would be astronomical and they won't do it.
Interestingly the K1600 has gone back to the design of the early K series. I wonder why!
What do you mean thank god for 1150's mine had 3 major FD bearing failures, one under warranty before I got it ,they were replace again at 25,000 by a BMW dealer in the UK and lasted justover 700 miles before going again in Austria where they were again replaced and reshimmed by a BMW dealer and they were f@@@ed 1000 miles later by the time I got home. Ended up avaing to put in a brand new bevel box.
So it is not just 1200 fault
That's weird .... I've been in the motor trade for over 20 years and that's the first time I've ever heard of that and a Barrister told you that?
Any failure? so if a window regulator fails within a 6 month period from new you are entitled to a new car are you?
