Page 1 of 3 123 LastLast
Results 1 to 16 of 47
Thread: Workshop jobs
  1. #1
    Join Date
    Nov 2005
    Bideford, Devon
    Posts
    3,803
    Workshop jobs
    Although we generally adhere to the Steptoe policy of not planning for anything it may be helpful to know if anyone has any larger projects that they want to attempt over the weekend so that we can allocate the workshop space accordingly. If its just simple things like carb balancing then that is easy but bigger jobs might take a bit longer and take up time on the lifts. Simple services are no problem eg fluids and filter changes etc
    I'll start eg
    R80/7 RT Pink Lady's bike. I will hopefully have it almost complete by then and only require help from Rob Farmer for connecting up all the electrics.
    R100RS. This is running fine now but has tiny leak from pushrod seals so I may as well replace the pushrod tubes for stainless ones. Hopefully, I will get this done before the weekend to not take up workshop space.
    We can change tyres here if anyone wants that. We have a couple of air compressors and I'm reasonably handy with the tyre levers.
    Let us know of anything you are planning and we can make sure we have all the neccessay special tools etc in place.
  2. #2
    Appreciating Scotland Click here to find out how to Subscribe
    Join Date
    May 2005
    Glasgow, Scotland
    Posts
    8,297
    Will there be a timing strobe?
    '83 BMW R100
    Yamaha S10
    '69 BMW R60 US
  3. #3
    I should change this Click here to find out how to Subscribe
    Join Date
    May 2003
    and this as well...
    Posts
    17,896
    Quote Originally Posted by Packer View Post
    Will there be Tossers Tipple?
    Quote Originally Posted by Ronno View Post
    Then I remembered. He doesn't ride a GS. Therefore he aint at the sharp end of Dudeness...
    Quote Originally Posted by Wapping View Post
    'Where there's offence, there's brass'
  4. #4
    Moderator
    Join Date
    Mar 2003
    Nr Cardiff
    Posts
    4,230
    Quote Originally Posted by brassmonkey001 View Post
    I have an unopened bottle of the Tosser's Tipple that I could be persuaded to bring
    Planning on overhauling a pair of carbs off the G/S so would be looking for bright corner and some guidance from a learned one.
  5. #5
    Join Date
    Mar 2003
    North, London, England
    Posts
    4,179
    Just a full service on my R80.
    If time and bench available, replace the neutral switch.
    I'll contact Sherlocks re parts.
    Couple of minor oil leaks to identify, for another day.
  6. #6
    25 Mar 1949 - 10 Nov 2016 Click here to find out how to Subscribe
    Join Date
    Apr 2006
    Bollox yer nosey gits
    Posts
    11,440
    I've found mine out
  7. #7
    Join Date
    May 2007
    DERBYSHIRE
    Posts
    457
    push rod tubes
    May like to do push rod tubes as mentioned earlier Sid.
    Hopefully pick up on way through and early arrival should help get things out the way to then give others chance on arrival.
  8. #8
    Size 11.5 Click here to find out how to Subscribe
    Join Date
    Dec 2007
    Norf Staffs
    Posts
    5,289
    A 6 volt one?
    Illegitimis nil carborundum
  9. #9
    Join Date
    May 2007
    wet end of A133
    Posts
    1,758
    Quote Originally Posted by Bill-H View Post
    A 6 volt one?
    you got 6v HT leads then
  10. #10
    Join Date
    Dec 2007
    Norf Staffs
    Posts
    5,289
    Quote Originally Posted by bumpmuncher View Post
    No , but the two leads which power mine have to clip to a 12v battery, a seperate cable clips over the HT lead.
    When Packer used mine I had to run jump leads from my car battery to the strobe connected to his bike HT leads
  11. #11
    Join Date
    May 2007
    wet end of A133
    Posts
    1,758
    You dont need a 6v one then
  12. #12
    Join Date
    Dec 2007
    Norf Staffs
    Posts
    5,289
    -sigh- I'm not bringing my jump leads !
  13. #13
    Join Date
    May 2007
    wet end of A133
    Posts
    1,758
    there are usually a couple of batterys kicking around at sids (or there have been the last couple of wee'kends)
  14. #14
    Join Date
    May 2005
    Glasgow, Scotland
    Posts
    8,297
    Do bears sh1t in the forest?
    '83 BMW R100
    Yamaha S10
    '69 BMW R60 US
  15. #15
    Join Date
    May 2005
    Glasgow, Scotland
    Posts
    8,297
    A 6 volt one?
    I'm sure that there weill be some 12 volt sources.
    If we hide the battery that's supposed to go into Pink Lady'as machine until we're done...............................
    '83 BMW R100
    Yamaha S10
    '69 BMW R60 US
  16. #16
    Join Date
    Dec 2007
    Norf Staffs
    Posts
    5,289
    -sigh- I'm not bringing my jump leads ........
    ......or my strobe
    but I will be bringing a load of Jaffas
Posting Permissions
  • You may not post replies
  • You may not edit your posts
