***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
View Poll Results: Have you
Voters
270. You may not vote on this poll
  • Removed your Cat Code Plug
    31 11.48%
  • Left the plug in place
    63 23.33%
  • Never had one
    63 23.33%
  • What is a cat code plug
    113 41.85%
Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 49 to 64 of 143
Thread: cat code plug (AKA STEPTOE's LINK)
  1. #49
    gsmoose
    Originally posted by Steptoe
    it codes the engine for running with a can, and without a cat, its the stage 3 setting for a BB chip, but does the same thing without the chip
    Hi Steptoe,
    Is that with the Lambda or without, or doesn't it
    matter?
  2. #50
    What a waste. Click here to find out how to Subscribe
    Join Date
    Oct 2003
    S/W London.
    Posts
    52,405
    Originally posted by gsmoose
    Hi Steptoe,
    matter?
    it's for the 1150 ( which allhave lambda probes , although i've seen a few with it removed ? ) -
    All your BMW servicing needs at the .gsshop.biz, including 1200 models
    Recommended as an "excellent independant" in Ride magazine 2009.
  3. #51
    gsmoose
    Many thanks Steptoe,
    Can you recommend a setting for no cat, OE can?
  4. #52
    15mg and rising Click here to find out how to Subscribe
    Join Date
    Jul 2003
    Dinky Poo in Wales
    Posts
    1,201
    WTF cant ya put it in the http://www.ukgser.com/info/wisdom.htm
    Section , with info broken down
    IE
    with cat - race can
    Y and race
    Y and standard
    Y and Legal can
    Notes on position ect.
    that would be nice.
    B-cause i'm head ****** at the mo and cant work it out.
  5. #53
    Stay Frosty Click here to find out how to Subscribe
    Join Date
    Aug 2002
    Dorset
    Posts
    27,917
    IE
    with cat - race can
    Y and race
    Y and standard
    Y and Legal can
    that would be nice.
    if only it was that simple
    Ready To >> Rest
  6. #54
    Join Date
    Oct 2003
    S/W London.
    Posts
    52,405
    Ride it -
  7. #55
    bikemike
    Hi guys,
    Have yet to do an introduction but I was referred here by the ADVrider forum because of '04 idle and surging/acceleration problems. I just came back from a 10 mile test ride after doing the "steptoe mod" and the bike has not felt this good for 9000 miles. Do I need to reset the motronic? I may as well. Am gonna reset, resynch and ride for a few hours tonight..if this works, steptoe you are a bloody genius but I'm gonna tell everyone over here it was my idea.
    Cheers!
    Mike
  8. #56
    snoopy
    I've also removed the end can and kept the CAT. Bike had minimal surging but was snatchy at low speeds with plug. Removed plug and fuel consumption went up, performance was crap and my panniers got covered in carbon. Just did the Steptoe mod, performance same but engine is very smooth and spins nicely. Lost a little top end however where it is leaning out. Get's my vote.
  9. #57
    Senior Member
    Join Date
    Nov 2004
    Belgium, Overijse
    Posts
    320
    Is there a chance of damaging the engine when trying the steptoe mod?
    I run a Ypiece and the OE can but I am suffering low mileage. I don't have and never had any CCP. Bike's a 1150 GSA twin spark.
    If I read about burnt valves and holed pistons...
    Tnx for your advice all
    T
  10. #58
    Senior Member
    Join Date
    Aug 2003
    Brighton
    Posts
    1,193
    I've just done the steptoe mod ...
    As he was right about my lights and the "Fuse 3" problem it semed like a good idea...
    Can I assume that the bike just resets itself to the new "code" or do you have to press and twiddle things randomly to get it work ?
  11. #59
    Join Date
    Mar 2007
    Near Sevenoaks,Kent
    Posts
    3,821
    Quote Originally Posted by Steptoe View Post
    this is the same as the relay you get, your only paying for the box !
    this is plugged in to run a Y piece, and remus .
    HI steptoe, ive got a 2004 gsa 1150 running std exh and cat thingy.just checked your piccy and my cat code plug hole is empty.
    But ive just bought a remus y piece and revolution silencer, so i will use your linky thingy piccy and make up a wire link.thanks for the info.
    Paul
  12. #60
    Senior Member
    Join Date
    Jan 2007
    Spain
    Posts
    167
    CCP pin numbers
    2003 1150adv , pin numbers on the relay board are 5 & 6 for the same positions as Steptoe's photo (stated originally as 5 & 0), possibly numbered differently over the years.
  13. #61
    Member
    Join Date
    Oct 2007
    Farnham,Surrey
    Posts
    15
    You cant use this as a datum for your own bike, but as I havnt seen anyone's dyno charts re this CCP mod and changes to the system in general. I thought Id pitch in with some data.
    GS1100R.. Remus revolution (with legal insert silencer), stock filter and light brown CCP, no cat bike as standard (hence the CCP)
    Ran brill, no surge or hunting, slightly over fuelling.
    Installed K&N today.... ran awful, surged, hunted, poped and banged on overun
    Remove CCP, Reset motronic, Then pulled some runs.. perfect.
    F/A rich 14.2 at 2k, is a little lean at 3k, cock on at 5k, leans at top... nothing worse than 11.8:1
    No chip, no pc...
    77.1 bhp
    Just for kicks took a look at stock pipe with stock filter & CCP in...... 76.6bhp.. ran perfect, same profile. just lower af peaks and troughs
    Pipe and k&n on a GS.... runs awful with CCP in
    One things for sure, Remus's are as restrictive as stock...
    cheers Toaster
  14. #62
    Join Date
    Oct 2003
    S/W London.
    Posts
    52,405
    Quote Originally Posted by Toaster193 View Post
    There are some dyno stats for the mod on the forum. Try a search.
    The general gist if it was, as far as i can remember - it tested as a bit more mid-range, but losing out at the very top end. And a slightly richer mixture in the midrange as well.
  15. #63
    Join Date
    Oct 2007
    North Wales
    Posts
    38
    1150 Cat code plug
    I have just read the thread about linking up connections 5 and 6 on the cat code plug.
    I have only recently bought my 1999 1150GS and it came with a Y piece and a Remus and also a Techlusion black box fitted. It seems to be running OK, however since this is my first GS, then I have nothing to compare it against.
    I was wondering whether I should try the cat code mod, or does the techlusion black box mean that I don't need to do this. I am just afraid that I might do some damage.
    Any thoughts or advice?
  16. #64
    Senior Member
    Join Date
    Sep 2006
    Sheffield, England
    Posts
    647
    Click here to find out how to remove these ads
    sorry to drag up a old thread....
    my GS is without plug at the moment, not sure where it went, of if it was ever present.
    but for the less intelligent folk could I just clarify.... particularily Steptoe if possible....
    pins 5 and 0 jumpered would be best for y peice and OE exhaust?
    and....
    pine 5 and 6 jumpered would be best for y peice and after market slip on exhaust?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
