Took my 1 year old R1200GS to Bahnstormer today for an annual service and purchase and fitment of LED spots. Had one fault to report to them that in the last 100 miles gearbox selection starting to play up. When changing down the lever is not returning to normal position hence when trying to change down again its a no go, only way to correct to tap the lever up a little then down again. quite tricky when dropping 2 or 3 gears in quick succession.
OK sir will look into that, after the service complete, they had cleaned out and greased up test ridden it and declared it all good.
10 miles up the road obvious it was still there as bad as when I rode in, every down change apart from the first down change needed the flick up before down for every gear!!!
Had to get home, so couldn't afford the time to go back, call them up and soonest they can pick the bike up is 4 days time!! and then in the middle of the day(well I work) any chance of a loan bike ? No !
Really unhelpful ! an error on there part and can't put themselves out to correct the situation. I have been going there out of area to use them, just spent over 600 quid this visit...there 3 dealers nearer to me, looks like that is finished for me, bye bye bahnstormer. Its not making a mistake its how you correct it, in there case it seems we don't care!!
Fine called out the breakdown for recovery.
