I haven't used my Suzuki GS850GT since February and after putting it the bench to do the oil and filters I found the crank case had filled with petrol via cylinder no 4 which was still half full of fuel. Luckily I didn't try to start the bike The vacuum petrol taps on these bikes are crap and I intend to blank the vacuum pipe to the carbs and fit a gravity fed petrol tap that means I will be able run the carbs dry when I park the bike for any length of time and generally not worry about fuel leaking from the bike (which has happened before).
My question is how did so much fuel manage to run through a carb? Do the float heights need resetting or did the amount of fuel the poxy fuel tap leaked through just overwhelm the carbs?
