So its not the ABS then
Yes it is in this case, because I was PM'd and told exactly how old the brake fluid is.
So, would bleed the ABS unit to flush the 2 decade old fluid out and would do it before the caliper.
Next
Next
I suppose so... might as well go steel braided while I'm at it. I'll give Mr Sherlock a bell tomorrow..... the brake hose WILL be replaced before it splits won't it Paul?
Paul, I've just received a set of braided, clear plastic coated hoses for my K75 from Motobins.I suppose so... might as well go steel braided while I'm at it. I'll give Mr Sherlock a bell tomorrow.
Thanks again chaps, I'm due to get my eyes lasered next week so I better get it done and back together before then in case it all goes pear shaped
I flipping hope so, they're only doing my dominant eye. They say if they do both I'll need reading glasses in situations where I don't at the moment.You'll be fine .....
Thanks Mike, I always try Sherlock's first but on this occasion they couldn't help.Paul, I've just received a set of braided, clear plastic coated hoses for my K75 from Motobins.
They might be worth checking against Sherlock's prices:
http://www.motobins.co.uk/bmw-parts.php?model=R850 R1100 R1150
Yes, I know - old thread. Of the threads returned for my search, it's the one with content closest to my query.
My 1150 has non-servo ABS, with stainless hoses. I'm replacing pads and fluid in the next week or two. Can you guys confirm or correct a couple of things for me?
BLEED ORDER
If the order is important, why?
- Control unit front bleed valve.
- Control unit rear bleed valve.
- Front calipers.
- Rear caliper.
I read Steptoe's comment regarding bleeding the control unit not being necessary, but I want to anyway - it'll satisfy my OCD. Can bleeding at the control unit if it's not necessary do any harm?
What volume of fluid should I expect to use to flush/replace the control unit + front calipers + rear caliper, bearing in mind I'm also fitting new pads all round?
I'll be doing the job on my own:
If air floats to the top of hydraulic fluid, why do we usually try/expect to expel it from the bottom of a hydraulic system?
- Old-school manual repetitions of pump lever/open nipple/close nipple/top-up?
- Non-return hose on opened OE nipple? Which non-return hose?
- Speedbleeder nipples?
- Mityvac 8020 or (preferably cheaper) equivalent? Which one?
- Reverse-bleed from bottom up? Which kit/method?
Thanks.
BLEED ORDER
- Front calipers.
- Rear caliper.
Thanks.
You might as well change the clutch fluid as you're at it. You'll probably need to get a bleed nipple to do it, as some (all?) of them just have a connection with a one-way valve. You need to screw a bleed nipple into the valve to open it. I got a speed bleeder for mine - made the job very easy.
Can it replace the grub screw, and be left in situ? Or must the bleed nipple be removed and the grub screw replaced after bleeding?
Remove it and replace the grub screw. That is if the grub screw can be removed in the first place put the bleed unit in a cup of boiling water before you attempt to remove it as the grub screw gets seized and the hex is very easily rounded off...... If you can't remove the grub screw remove the complete spring loaded bleed unit and replace it with a bleed nipple.
