The paint on the fairing screws has cured but one of them had a badly chewed plastic washer and on another the washer was missing altogether.
Then I remembered that I had a couple of manky screws from my K1 in the bucket of old fixings:
They sacrificed their washers in a good cause:
My old bike will live on, albeit it a very small way, in a snug carcoon thing.
Next to get the clean and polish treatment was this:
Stripped:
Cleaned and polished:
I did raid my supply of stainless fasteners for a couple of nuts and the retaining screw:
That package from Motobins arrived this morning as I was working. The contents: New fuel filter, plugs, stainless rear calliper mounting screws and new tank badges (both those fitted are de-laminating):
A dab of aluminium anti-seize on the threads and in with the new plugs:
A squirt of this:
Then re-arrange the leads (they are handily numbered):
Fitted the stainless calliper mounting screws (another daub of aluminium anti-seize):
Using the feeler gauge from the pristine tool-roll, checked the ABS sensor gaps front and rear:
Finally, greased and re-fitted the gear pedal and linkage:
Hopefully, I'll get all the other little jobs done before the panels with the body shop are ready. Still to do:
Replace tank badges.
Change the fuel filter.
Re-fill the system with fresh coolant (25% anti-freeze).
Re-fill gearbox, final drive and engine oil.
Fit new battery.
Strip and re-spray battery retaining strap.
Re-fit Motronic unit.
Re-fit ABS control unit.
Re-set the ABS (fingers-crossed).
Re-route and secure all cables and wiring.
Re-fit both parts of rear mudguard.
Re-fit and adjust the bench seat release mechanism (the seat wasn't fitting properly).
Both helmet locks need cleaning-up before the rear quarter panels go back together.
All the painted body panels that have not gone for repair need a cut and polish.
Happy days ahead.
