Last night the tank went back on and I replaced the badges:
It was treated to a good polish (as were the end weights):
Next job was to re-assemble the seat latch mechanism. It's essentially the same as that of the low seat models but instead of the release being operated by a rod that's actuated by the normal seat lock on the frame, these are cable operated with the handle inside the nearside cubby.
When Mike delivered the bike, he pointed out that the seat didn't fit properly. At the front, it sat too high and too far back from the rubber shroud.
Last night I re-fitted the shroud (temporarily as it hasn't yet had a scrub and polish) and fiddled with the lock mechanism to try and sort out the height problem.
This is as good as I could make it:
It's still bad but not as bad as it was. Next thing was to adjust the latch on the seat itself but here's where I found a problem: The latch on the underside of the seat should be held by two screws with fore and aft adjustment. Instead it was held by four self-tapping screws, not only that but it was upside down.
The two arms of the latch should sit inside two matching grooves.
With it off it all became clear:
There's also the remains of some glue that was used to try and repair the broken section:
I replaced the latch, the correct way-up by using the four screws, only three of which actually did anything, the fourth was screwed into fresh air.
Offering the seat back onto the bike there was some improvement but not much simply because the plastic seat base flexed, allowing the whole thing to pull against the rubber pads and the frame rails:
I had a quick look at the fiche before turning-in. The good news is that of all the seat versions, only the black is still available as a complete item and not just a new cover. The bad news is that it's over 500 quid!
Sleep is a good idea and in the morning I'd thought of a fix that might work. So this morning I cut a piece of aluminium plate to fit inside the hole left by the shattered plastic. The idea being that the plate, cut longer than the recess will pull towards the latch when it's drilled and tapped with a suitable thread when the original mounting holes in the latch are used.
Well that's what I did (photo isn't too good but the plate is in and bonded to the underside of the plastic):
The pliers and the button-head screw were used to position the plate and to hold it in place while the glue went off:
A bit later and the latch is fitted and can be adjusted fore and aft as intended. It's also less likely to pull and distort the seat pan:
The results:
Still not perfect but possibly acceptable...........Mike?
The only explanation for the damage to the seat base where the latch mounts, is that someone didn't know how to remove the seat and forced it.
I put ten litres of fresh fuel into the tank and then made a big mistake.
I'd forgotten how addictive the sound of a 16-Valve K100 motor is.
Worse, I swung my leg over and was happy to discover that the position is still the most comfortable I've ever known (yes, even the rear-set pegs I find to be perfectly placed). The years rolled away and I was back on my much loved and sorely missed red & yellow K1.
The ABS re-set was successful and here the tacho shows the bike with a couple of thousand revs showing and the ABS light extinguished as it should.
There are a few more things to attend to (the devil is in the detail) and hopefully the painted parts will be ready by next Monday at the latest.
Hopefully I will be able to get it MoT'd on a dry day and then get some outdoor photos of the finished article.
