NEW LED DRL
New for next year from Durite, we have just got out sticky mitts on some samples of some rather nice superbright LED Daytime running lights
These are in sample packaging but will be a Durite product when released.
Two sizes:
LARGE
SMALL
Photos of lights when lit up are mostly BS, because they can show up as bright as you like just by adjusting the settings on the camera, but these really are seriously bright to look at!
Both sets come with a full loom fitted with an inline fuse and waterproof holder
Wiring- May seem unusual at first, but it does make sense when you play with them
Three wires.....one to earth (durr) one to ignition switched positive and the third (optional) goes to another live feed, and turns the DRL's OFF.
This means that with that third wire attached to main beam or dip beam feed, the DRLs are ON until you put the headlamps ON as well, at which point the DRLs are turned OFF.
(I doubt in honesty that many GSers will use the feature, but it's there.)
The larger of the two models comes with a bracket to mount onto a flat surface:
and the smaller one is designed to go into a recess and has a hole at either end to screw them in....it would be easy to make or find a bracket for those too though, or they could be cable tied onto/underneath a bar etc.
Front view of the larger one.....we left the plastic film attached by the way, as these are samples for evaluation and I have to take them back tonight.
This is the beam pattern as described on the box....long wide beam designed for visibility.
Both have die cast aluminium bodies and polycarbonate lenses and are fully ECE and CE approved.
We haven't got the final set in stone price yet, but we expect we will be able to supply these to Subscribed tossers at around (possibly UNDER) £30 a pair
EDIT.....we don't have the full PDF spec sheet yet either, but we believe they will draw under half an amp each, so well under an amp per pair.
This means that canbus bikes will almost certainly run them directly from the feed to the dip beam without any LAMPF problems, but will DEFINITELY be able to run them from the canbus take-off lead
Light colour is 60K white and they are IP67 totally waterproof.
