Well, I put an 'ad' for a couple of parts in the Wanted Section and there was some interest in the box I'm renovating for another member.
It came from a 1931 P&M Panther model 50 - but its a pre-'31 box as it has the single spring clutch, doesn't have a shock absorber in the clutch centre and has a loose ball race on the output shaft drive side instead of the later caged ball race.
So here are a few pictures of it as I took it apart and discovered things I didn't like .
This is the complete box with the kickstart lever removed:
The clutch pressure plate has a single spring and the boss just unscrewsd:
All the clutch components laid out (except the hub).
There is a rather crude roller bearing at the back of the clutch drum. The rivets holding it together are separating and I bet these bearings are impossible to replace. Time will tell.
The three-speed selector mechanism is rod operated from a lever on the side of the fuel tank.
Extracting the clutch centre:
The output sprocket is held on by a nut that is locked with a plate:
The clutch is operated by a 'quickthread' plunger operated by a lever.
The box is lubricated with Mobil 'Gargoyle' grease that is a thick gloopy oil. It flows so you don't get spinning bits drying-out inside. It doesn't want to come out though .
The second gear pinion on the output shaft engages internally and on the end. There is some wear in the dogs and one tooth is missing (its a 20-tooth pinion, Nortons used a 19-tooth close ration version ).
This is the main bit I'm looking for if anyone can help source one .
Underneath, a mounting stud was missing and the hole had been plugged with wood .
This is the three-speed cluster in 1st gear position:
Second gear position:
And third gear position:
The cluster with the kickstart shaft and gear lever added:
The kickstart shaft runs in a sleeve that is screwed into the end cover. This sleeve is (was - I've now bust it ) severely cracked. To date I haven't been able to remove the threaded base but I'll have to be a bit firmer with it. I'll turn up a replacement out of alloy.
More of the clutch operating 'quickthread'.
No mistaking the origin .
So, I hope you 'Classic Bike' people out there find this interesting. I'll add more as I re-assemble it (but don't hold your breath).
Bob.
Bob.
