Page 2 of 4 FirstFirst 1234 LastLast
Results 17 to 32 of 54
Thread: Suspension advice
  1. #17
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    No Problem, after that amount of miles they could do with a Birthday!!!
    Have a great Xmas and happy new year!! roll on dry weather
  2. #18
    Senior Member
    Join Date
    Jan 2006
    Maidstone
    Posts
    1,841
    Thanks FTR.
  3. #19
    Member
    Join Date
    Dec 2009
    Dublin, Ireland
    Posts
    45
    Hi
    Sorry for being stupit, but could you advise on Sag for the GS1200 with lowered suspension?
    Any help would be appreciated.
  4. #20
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    your welcome!!
    Definately after 90,000 your suspension will need a birthday...
    Merry Xmas and Happy new Year!
  5. #21
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    Hi,
    depends on how much and how it has been lowered? have the standard shocks been lowered by installing a spacer? or maybe lowering springs?
    can you give me more details on how it has been lowered.
    FTR
  6. #22
    Member
    Join Date
    Dec 2009
    Dublin, Ireland
    Posts
    45
    Hi
    The bike is the single cam 2009 model with factory lowered suspension
    Front standard 190 mm lowered 158 mm
    Rear standard 200 mm lowered 171 mm
    i hope this helps
    Pat
  7. #23
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    Hi Pat
    For your lowered version i would recommend 15-20mm static on the rear and 48-53mm Rider sag.
    For the front 30-35mm static.
    Regards
    FTR Suspension
  8. #24
    Join Date
    Oct 2006
    Blackpool
    Posts
    166
    My question is how do i improve the suspension/handling of my 2010 GSA with ESA. Its now done 25000 miles and feels like its gone off a bit to be honest when i occasionally ride a mates bike. Is it worth an overall or are their Wilbers i should look at or being ESA is it only the expensive Ohlims? thanks
    Neil
    10 GSA
    HP2 Sport....
    06 GSA
    Ducati Sports Classic
    R1100S
    SV650
    CBR600
    GS1000S
    GT750 'kettle' x2!
    RD400
    400FOUR
    KH250
    FS1E....
  9. #25
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    Hi, Unfortunately there are not many ( if any ) that will take on servicing the ESA system. We used to be able to when we were the importers for WP because we could obtain the service parts but since KTM closed the WP factory they are not availble anymore.
    It is becoming for common now especially between 20-25,000 miles that the ESA suspension starts showing signs of a decline in performance and the only way to improve the handling is to replace the system with a traditional non electronic set up. although Ohlins do produce a replacement Mechatronics system but it is expensive. but very good. If this is a direction for you then Wilbers, Ohlins, Hyper pro and Yacugar are all good options for repalcement aftermarket products. We are now replacing many of the ESA systems with non electronic suspension with great feed back and the customers are not missing the electronic options with the ESA.
  10. #26
    Ohlins for xt660z
    Hi
    This is for anyone in the know really
    Can anyone tell me the best price that I can an ohlins rear shock
    For my xt60z tenere. 2010 (not abs)
    New or used
    Thanks.
  11. #27
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    Hi, a new Ohlins starts at £490 for an emulsion unit with rebound damping and manual preload adjustment.
    Used prices will vary, if you can find one on the net as they are not a common shock.
    Regards
    FTR Suspension
  12. #28
    Thanks for reply
    No doubt they are an awesome shock but bit too
    Steep for me . Is there a certain shock I should be
    Searching for or a code, also is there another bike
    That shares the same shock that I could search for?
  13. #29
    Join Date
    Oct 2009
    Inverness, Scotland
    Posts
    294
    Quote Originally Posted by ftrsuspension View Post
    Very interesting point. The implications though are staggering for anyone contemplating a second-hand bike.
  14. #30
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    Quote Originally Posted by TENEREBOY View Post
    Thanks for reply
    Unfortunately these are the cheapest in the Ohlins range with there street line performance shocks so even one from another bike will be the same price.
    Ohlins is a high end product and do not try to be cheap because of there heritage.
    Yacugar produce the ERS emulsion shock built to your requirements for £358 inc vat. and has 5 year warranty!
  15. #31
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,451
    My (ESA) bike had 32K on the clock but only 5K on the back shock because it was replaced under warranty.
    Before its too late, I fancy having a Wilbers WESA and recouping some of the cost by selling the nearly new BMW ESA shock with its warranty provenance. The front is the original so wont be worth as much as the back.
    08 R1200GSA
    76 Suzuki GT750
  16. #32
    Member
    Join Date
    Jun 2010
    Bury St Edmunds
    Posts
    45
    Click here to find out how to remove these ads
    Quote Originally Posted by Bendy toy View Post
    We are currently offering an exchange scheme for oem shocks which helps towards an aftermarket new shock.
    http://www.ftrsuspension.co.uk/exchangescheme.htm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
