Stripping and cleaning goes on. All the body panels have now been removed, stripped of their fixings, cleaned and will shortly be delivered for re-spraying (a change of colour has been decided upon).
In the mean time I've been removing the paint that has been liberally sprayed over all sorts of things such as the air-box snorkel:
The coolant has been dumped and the system stripped down:
The radiator removed, the fan checked that it operates correctly and cleaned:
All the hoses and clips have been cleaned, the hoses given a dose of rubber food stuff and the snorkel given a buffing:
The fuel cap is grubby, plenty of white fluff on the rubber gaskets:
They are easy to remove, just four crosshead screws. It's not as if the rubber seal needs to be replaced or is as fiddly to re-fit as some later models. It has to come out to do a fuel filter change. I just don't know why people don't clean them at the same time. I'm convinced that most of the water that finds its way into K-Series tanks is due to the poor seal caused by the oxidisation.
A quick wipe with acetone soon removes any old polish that makes the black finish look scruffy:
The more observant will have spotted that the steering has been stripped:
The steering bearings while not exactly shot were showing signs of brinelling so they will be replaced. The dust caps are always sacrificed when removing the bearings:
When I released the fork stanchions, lots of heat was needed to release the clamp-screws and they came out packed with oxidisation so I cleaned the threads out with a tap:
The insides of the clamps are pretty rough too:
A light spin with an emery wheel sorted that out:
Then the bottom yoke was given a clean up:
The top yoke was a bit furry too:
After:
Then onto the shelf ready for when the new bearings go on just before re-assembly begins:
It's early days yet, the box of cleaned parts ready for re-assembly is far from full but the pile of bits for painting is getting to the point where I'll have enough to set-up my "spray booth".
I'm not certain that the frame can be cleaned up. I may whip it off. It's only five bolts. We'll see.
