Michael R1150GS Adventure
i feel like such a baffooon
Does that only happen when the river is in full flood?
So where are these fast sparks coming from if the power to the coil has been cut courtesy of the kill switch... Electrical sparks
I'm still confused.... I've had cases of carbon build up on top of the piston causing ignition, but not these fast sparks.
I guess if pulling off and yanking saved your day that's great
... Cover the exhaust with a gloved hand, to stall the engine ...
Put it in a high gear, stick the front wheel against a solid object, dump the clutch and jam the brakes on to stall the engine
Are you sure the engine stopped because it seized? Might it have flooded or oiled up?
Just had a search & read on Trials Central and they just confirmed my thoughts, because the engine is screaming, there is is so much electricity going through the system the kill switch can't arrest it
It has been suggested ...
Yank the throttle cable to drop the carb slide
Pull off the HT lead
