Newbie
Silversurfer
Teesside
Hi All,
Although I have been a forum member for awhile I am new to the Triumph section. Just P/X'd my F800GS for a Tiger 800. Test rode the 800XC and loved it - great engine. Don't collect the Tiger for another couple of weeks but have a couple of questions.
Warranty - does the Triumph Warranty cover Europe?, (got conflicting advice from dealer). All other new bikes I've had in recent years have all included full European breakdown for the first 2yrs - can't find any info on the Triumph site.
Read through a couple of Triumph Forums and Triumph's reputation regarding warranty claims appears to be a little "suspect". Read through the owners handbook and Triumph's "Warranty Terms & Conditions" for the Tiger and have never seen so many warning notices and disclaimers - must have been written by some Brussels "Elf & Safety" bureaucrat.
Would appreciate any comments from the forum regarding the above and have any of you had any problems with the Tiger 800.
Many Thanks
WARRANTY TERMS & CONDITIONS
Maximum pleasure. Maximum protection. All new Triumph motorcycles come with a 24 month unlimited mileage warranty.
This motorcycle is the product of Triumph’s use of proven engineering, exhaustive testing, and continuous striving for superior reliability, safety, and performance.
Maintain maximum protection under warranty by ensuring your motorcycle is serviced in accordance with the recommendations of the scheduled maintenance chart in the owner's handbook. The appropriate service record must be stamped by your authorised Triumph dealer.
Whenever service, repair or warranty work is undertaken the motorcycle service handbook must be made available to your Triumph dealer.
Within the warranty period, Triumph Motorcycles Ltd warrants the new Triumph motorcycle to be free from any defect in materials used in the manufacture, and/or workmanship at the time of its manufacture.
Any part found to be defective during this period will be repaired or replaced at the discretion of Triumph Motorcycles Ltd by an authorised Triumph dealer.
Any part replaced under the warranty will be covered for the remaining period of the warranty.
Any parts replaced under warranty must be returned to Triumph Motorcycles Ltd by the dealer/distributor and will become the property of Triumph Motorcycles Ltd.
Triumph may, at its discretion make any repairs or replacement of defective parts falling outside the warranty, but such work shall not be deemed to be any admission of liability.
Triumph will bear labour charges for work carried out under the warranty. The warranty may be transferred to subsequent owners for the balance of the remaining period.
Conditions and Exclusions:
1. The machine must not have been used for competition, *misused, inadequately maintained, or incorrectly serviced or maintained.
2. The machine must not have been subject to any modification, repair or replacement other than as authorised by Triumph Motorcycles Ltd.
3. The machine must have been serviced by an authorised Triumph dealer, at the intervals specified in the Triumph Owners Handbook and the service log completed accordingly.
4. Defects caused by faulty adjustment, or repairs and alterations performed by a non-authorised Triumph dealer are not covered by this warranty.
5. Defects caused by the use of parts and accessories not authorised by Triumph Motorcycles are not covered by this warranty.
6. The warranty does not cover the cost of removal and replacement of parts and accessories, unless supplied as original equipment, or recommended by Triumph Motorcycles Ltd.
7. The warranty does not cover the cost of transportation of the machine to or from the authorised Triumph dealer, or expenses incurred while the machine is off the road for warranty repairs.
8. Normal servicing and normal service items, such as spark plugs, oil and air filters are not covered by this warranty. Similarly items which are expected to wear as part of their normal function such as tyres, bulbs, chains, brake pads and clutch plates are also excluded, unless there is a manufacturing defect.
9. Front fork seals are not covered by this warranty being subject to wear and tear (particularly stone damage to inner fork tubes).
10. The motorcycles exhaust silencers are warranted for 12 months from the commencement of the general motorcycle warranty. During this 12 month warranty period, internal corrosion or deformation of internal baffles are excluded from the warranty. After this 12 month period, the motorcycle silencers are excluded from the terms of this warranty. Unless otherwise stated, Triumph accessory mufflers do not conform to on-road noise or emissions standards in countries where such standards apply. Use on-road may therefore violate the law. These products are designed for closed circuit competition use only. Triumph accessory mufflers will require a specific tune download, which is available from your authorized Triumph dealer. Specification may vary by market. Some accessories are prohibited by local law. As a motorcycle owner/rider, it is your responsibility to know of and comply with all local laws. If you have any doubt, contact your local authorities. All details correct at time of going to press. Triumph Motorcycles Limited reserve the right to make changes without prior notice. Please consult your dealer for model and color availability.
11. Other items excluded from warranty are seats, luggage, paint, chrome, polished aluminum items, or trim deterioration caused by normal wear and tear, exposure or lack of correct maintenance.
12. The motorcycle battery is warranted for 6 months from the original date of purchase of the motorcycle. After this 6 month period, the battery is excluded from the terms of this warranty. The battery supplied with the motorcycle must be provided with sufficient charge to replenish that lost by the operation of the starting mechanism and/or the use of electrical equipment whilst the engine is not running.
13. The warranty does not cover machines used on a commercial basis.
14. The warranty does not cover defects which have not been reported to an authorised dealer within ten days of discovery of the defect.
15. The warranty does not cover machines which have been inadequately lubricated, or for which the wrong fuel or lubricant has been used.
16. Should a warranty claim become necessary, Triumph Motorcycles and its Authorised Dealers shall not be liable for loss of use, inconvenience, lost time, commercial losses or other incidental or consequential damages.
This warranty shall be interpreted in accordance with English law and any question arising from this warranty shall be subject to the jurisdiction of the English courts.
Any statement, condition, representation, description or warranty otherwise contained in any catalogue, advertisement or other publication shall not be construed as enlarging, varying or overriding anything contained herein. Triumph Motorcycles Ltd reserve the right to make alterations or improvements without notification to any model or machine without obligation to do so to machines already sold. This warranty does not affect your statutory rights.
Service Record
Motorcycling will be enhanced by the knowledge that your machine is being serviced to the high standards demanded by Triumph Motorcycles Ltd. Your motorcycle may require more frequent servicing if operated in severe climates or conditions, or if used for short, stop—start journeys. Further information can be obtained from your authorised Triumph dealer.
The first service must be carried out at 500 miles/800 kilometres/1 month, whichever comes first.
*Misuse includes any use not in accordance with the recommendations made in the ’how to ride the motorcycle’ section of the owner's handbook and any use contrary to the warnings given in that same handbook. In addition, misuse will include, but not be limited to any use of the motorcycle which does not constitute normal road use
IIRC you only get a 1 year Breakdown Recovery which includes Mainland Europe
If in doubt give the Warranty Dept at the Hinckley factory a call on Monday on 01455 453128 :thumb2
Warranty Queery
Thanks for that - the dealer seemed to think that the warranty was for 2yrs but breakdown cover under warranty only applied to UK via a 1yr membership of the RAC and that the cover did not apply to Europe.
Will phone Triumph on Monday and post what they say.
Hi, just looked at my Triumph RAC card that came with my Tiger 800XC an it appears you can upgrade to European cover at an additional cost, even gives you a number to phone. UK RAC cover is for one year only, Triumph warranty is two years. Hope that helps.:thumb2
Hi jmh
Yes it's 2yr warranty, 1yr RAC, extendable to Europe with additional payment.
Annoying really as last 2 new bikes, BMW/Honda both came with 2yrs warranty and 2yrs European breakdown cover.
Checked with RAC and 1yrs European breakdown cover is between £130 and £166 depending on countries to be visited.
Currently insured with Carole Nash fully comp on BMW F800GS for £149 including European Breakdown cover so will stick with them for insurance.
