Just looking for a bit of a sanity check please:
I have been having running problems with my Z650 F2. It would start and run fine warm up and the run rough on 2/3 cylinders and eventually cut out. It would then be a nightmare to start until it went again.
I was convinced it was fueling and therefore have had the carbs off for a clean and replaced the float valves.
Come to start it up again, with fresh fuel and now got it started but running rough. It seems it was only running on 2 cylinders. Outside 2 exhaust outlet were cold whilst inner 2 were hot (burnt hand). I can see that the 2 outside HT leads go to the same ignition coil. Would it be a fair assumption that the coil has been breaking down and is now shot?
Would love to get this running well again as I really need to sell this.
Cheers in advance.
Daniel
Cheers in advance.
Daniel
