Results 1 to 15 of 15
Thread: Upgrading trike shocks
  1. #1
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
    I now have twin shocks now on the softest setting, on the back of the beast, it handles well but there are times when I get a bit of wheel spin and feel the rear suspension can't keep up On rough back roads.
    The axle is a cut down reliant with 205 17" tyres on I have them at 23psi
    Any one know what might be good replacements please?
  2. #2
    Never knowingly understood Click here to find out how to Subscribe
    Join Date
    Nov 2005
    South Yorkshire
    Posts
    17,284
    A swing rear axle from a Triumph Herald to give independent rear suspension, combined with a limited slip differential
    Or you could slow down ya fecker
    Adventure.GS
    Tours, training or custom made earplugs ... it's all here.
    "If you want the rainbow then you have to put up with a little rain" Dolly Parton
  3. #3
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
    Naaaaaa, that is why i am interested in the suspension, that or fiddler brakes fitted to thumb levers.
    there is a slight loss of power to tyre spin coming out of tight fast turns after the light/ air born wheel hits the road, like a bit of bounce.
    If I time it bang on I can shut the throttle as it hits and wind on again just as it gets full grip again.
    As I am applying the power before the apex on most turns, any rough suffice mid bend can have the same affect as most of the traction is going through the heavy out side wheel.
    i love my blast Sunday morning 5:30 out over wood head, across to Glossop over the a57 then all back roads down to Matlock for a cup of tea.
    Next to no one about and I can really get the wind in my hair.
    I have been told it is impossible to get air ..... proved that's a load of rubbish, twice last Sunday.
    The chap that spanners it, has Got a bit of welding to do to the axle it has some cracks around one of the brackets on the axle. every time I hobble in to the work shop he says what you broke/bit fell of this time, the man is paranoid and developing a tic
    He says "you did what!" a lot as well.
  4. #4
    25 Mar 1949 - 10 Nov 2016 Click here to find out how to Subscribe
    Join Date
    Apr 2006
    Bollox yer nosey gits
    Posts
    11,440
    Hi Mark...
    Try dropping your REAR tyre pressures to 12 psi TWELVE...
    It also helps if your tyre section is a55/ 65 [ eg 205/65/ 17 }
    Even on Rocket 3 trikes I never ran more than 15 psi rear.
    My K75 trike runs at 12 psi, even 2 up, I've got a full size Reliant axle with 195/65/16 iirc
    If you have a lower tyre section eg >> 25 or even 35 the sidewalls are too hard to help the suspension and cause the bounce you're getting even at 12 psi.....
    Last edited by (RIP) Proff; 29-05-13 at 21:34. Reason: screwed the sectioning ratios.. I'm old you know !!
  5. #5
    Join Date
    Nov 2005
    South Yorkshire
    Posts
    17,284
    Quote Originally Posted by Proff View Post
    Hi Mark...
    It also helps if your tyre section is a 65 [ eg 205/65/ 17 }
    If you have a higher tyre section eg >> 75 or even 80 the sidewalls are too hard to help the suspension and cause the bounce you're getting even ay 12 psi.....
    You're probably right Proff
    I followed Mark round the Borders, he was airborne most of the time. The tyres being designed to carry more weight than the trike had
    He might as well have been on solid rubber
    Adventure.GS
  6. #6
    Join Date
    Apr 2006
    Posts
    11,440
    I've been known to get a bit of a hop on myself Micky.
    137mph on a Rocket 3 trike was amazing and completely unintentional.
    We ( Wackeys} recommended 55 {lowest} or 65 section {normal} tyres, never lower sidewalls One owner insisted on 225/35/19 on a Vmax trike, it was unrideable in my opinion, We even put a set of 16" rims with 65 section on temprorarily to show the guy that it COULD be a really good handling trike
    BUT he insisted on the bling wheels, even after admitting it rode brilliantly on the high sidewall tyres...... made him sign a disclaimer before releasing trike to him
  7. #7
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
    I have gone from 8 to 23 psi in slow increments.
    I am a lot fitter now than when I fist got it plus the trail reduction mod, so can pull it through the corners a lot tighter and faster.
    I am thinking of stiffening the shocks then going through the psi thing again.
    Just hard work, I have to pick my days when I can do this.
    I need a pit crew and a race track and some nitrous
  8. #8
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
    I did the presher thing again going down at firs 2psi then 1.
    Any thing below 13psi I start getting alternate bounce which build in to front end weave at any thing above 70mph on slightly rough roads.
    Balance cornering speed and ride comfort 17psi, at this the ride is good and I get that positive set as the weight shifts across entering a corner, and i can take my hands off the bars 70+ on a slightly rough road.
    This is after making the shocks as soft as they will go, I will repeat this after stiffening the shocks.
    The man that built it and keeps the thing together has com up with a cunning plan, a belly pan is to be crafted to run from the back of the oil sump to the first lateral anti twist strut* this and the new mud gards should rectify the huge folowing spray/cow crap cloud problem I have.
    *the first crossbar under the pivot.
  9. #9
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
  10. #10
    Join Date
    Feb 2006
    Huddersfield
    Posts
    1,598
    shocks
    not being silly that shock looks very similar to a lambretta shock
    NOW a guy called ian frankland fitted a vertually identical shock from a 2000 year yamaha R1 he had to put softer springs also he made some adapters for the eyelets
    plenty olins from them old bikes in the breakers
    worth TRY
  11. #11
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
    I have had a look around for two identical mono shocks to come up at the same time, being mono shocks there is a flaw in that plan
    If I can drop on two identical ones making them fit should not be a problem within reason as the bottom bracket can be replaced.
    I would think any pair of 600 sports bike ones, as loung as they have rebound adjustment.
    The mad mechanic at the ferret works* "tha rides it like it wa nicked all time" I have taken out some Anglo Saxon, May be a small factor.
    They want me to test out a new rear brake disc kit for the reliant axle, this I can't understand as I try not to use them!
    This will stiffen
    *yorkshire version of the USA skunk works
  12. #12
    Join Date
    Feb 2006
    Huddersfield
    Posts
    1,598
    R1
    The 2000 model R1 has the canister faxing upwards looks like a real deal on your trike
  13. #13
    Senior Member
    Join Date
    Oct 2006
    rotherham
    Posts
    207
    I have had the trike striped sand blasted all the welds inspected and repainted.
    A new clutch and slight mods to the brakes.
    I have two hardly air shocks for it now as the others are about had it, still awaiting fitting as the opv (old plumbers van) comes first.
    The last big trip I did was a lap of Spain and Portugal with a flock of harly riding hells angels, they always cheer me up when I fall over by laughing and pointing, wafting forbidden food at me and genarly not wrapping me up in Cotten wool.
    Though I did nearly get them all beaten up in Portugal, boy did we laugh.
  14. #14
    Join Date
    Sep 2008
    Nr Bakewell
    Posts
    713
    Quote Originally Posted by markg0vbr View Post
    Why do you think we always let you ride at the back - 'go on Mark, you make a really good tail end charlie'
    Life is short.
    And random.
    That's all you need to know...
  15. #15
    Join Date
    Sep 2003
    Northumberland
    Posts
    6,095
    Those shocks look like cheap R &R items or similar, they are useless on a twin shock bike, always far too hard and seem to be designed ! for any bike from 250 to 1300 cc
Posting Permissions
  • You may not post replies
  • You may not edit your posts
