Going to look at a K75 tomorrow afternoon.
1990, approx 60k miles. Photos look good.
What to look out for, please.
With the K75, the three cylinder version is the best.
??? Have you seen anything other than a three cylinder version?
It's a K75S ....
.... It is a three cylinder. The extra cylinder was removed at the last service as it served no purpose.
Great bike's Kami
See it?
Like it?
Buy it
It's a K75S.
Straight bike, missing left side panel, original red paint but worn around edges.
Really smooth, quicker than I expected.
Didn't like cats eyes or ridges.....I suspect worn head bearings but I'm not mechanical, so not sure. Forks seals seem ok. Rode it for about 30 miles. Completely dry.
Don't think ABS works.
There was a sort of hissing noise as it idled. He suggested it might be the fuel pump. Hissing might not be the best description, though. again.
€600 (£500)
The ABS1 takes a lot to get it to work. If nothing else it will teach you that you can brake a lot harder than you may otherwise have thought.
Ignore the hissing, quite normal.
Cats eyes and ridges, it will be on bias belted tyres most will skip when they hit them but that's all. Try Pirelli Demon Sports, probably the best grip you'll get without changing the wheels to sizes that will take radial rubber.
If there is a problem with the steering, it could be either the bearings or the fluidbloc damper. Neither are hard or expensive to fix.
Thank you Gents.
Very informative comments from the most knowledgable members.....valued and appreciated.
Deal is done.
I was confident I wasn't making a mistake and the responses confirm.
Looking forward to picking it up, riding it, cleaning it (a little, 5% of what MikeP would do), riding it, making minor changes as suggested and riding it and riding it and more riding it.
