Has the drain plug been refitted recently? Otherwise it is unlikely it will have started leaking after a period of time. To be sure of the origin of the leak I would clean off the underside of the motor especially everything forward of the drain plug and check again. Maybe there is a leak from the water/oil pump which is migrating rearwards. The important thing is to establish exactly where the leak is coming from.
How much is actually leaking?
