Hi again, all!
I read a comment on this forum about the 1200 needing TWO separate PC's: is that really true? It said because each cylinder had a different map. That seems a bit over the top.
I looked on the PC site and it doesn't list my bike, only seems to have the later street versions. Not sure if that would be an issue.
The PC electronic module 'talks' to the Autotune electronic module via a two-core length of flex. Ideally, they need to be mounted fairly close to one another.
From that 'base', you have a choice of using either one or two wide-band Lambda sensors. If one, it should be mounted at the exhaust-header Y-piece, just before the cat. (Cutting and welding will be required). If two, you can simply unscrew the original narrow-band sensors and the wide-band sensors will be a direct 'drop-in' replacement.
So if you want to go the Autotune route with minimal fuss, you need two Lambda sensors and one AT-300 module.
IIRC, the HP2 Enduro used a version of the boxer engine that was basically identical to the 2009 R1200GS engine of the same vintage - right down to power output. If that's the case, and the HP2 engine uses the same throttle-position sensor and fuel injectors, a PC V meant for the GS will slot right in.
After that, it's be relatively simple to tweak an R1200GS map to suit.
This is the comment about needing two PC's. But re-reading it, maybe he doesn't mean tow PC's, he says two "units". What does he mean? Do you agree?
"pcv will fit ok on your 08 i have one fiited to mine and as a note the maps available on pc website pcIII for 08 bikes are compatible all you have to do is fill in the 15% throttle column in the pcv map.you can either cut & paste the maps or enter manually or you could add the auto tune modules and then no map/dyno required but you would need two units as the bikes has a seperate map for each cyclinder but at the moment dyno jet are still configuring the firmware on the pcv to accomodate two autotune units."
Nope.
See my comments above. The setup I described above is what's currently running on my bike.
I think you replied to an earlier post I'd done.
But do you know exactly what HillTop does?
Geoff said they completely redo the original BMW firmware when I spoke to him, but I don't think he really means that.
I think that's too much to do: it's all proprietary firmware, think would be a big job to recode that for every bike they did.
Max at MaxBMW in the USA has done quite a few HP2's: he says he just replaces the BMW maps, I think with several maps.
I'm pretty sure HillTop does the same.
From my understanding of it, that's exactly what they do. The original ECU map is simply replaced with an altered map by re-flashing the ECU.
It's actually exactly the same method that a PC owner uses to replace the map on his PC by using a laptop computer (the difference being that if you want to do the same to the BMW ECU, you need the proprietary BMW equipment, which is not available from your friendly local computer supplies store).
At the end of the day, assuming the relevant map is well thought-out, you will get exactly the same result.
Remember: a PC works by 'intercepting' the input (TPS) and output (fuel injector) signals from the BMW ECU, altering the injector output signals to conform to the given map, then forwarding them to the injectors.
A possible advantage of re-flashing the original ECU is that you might be able to play with the ignition advance mapping as well.
I know it IS possible to rewrite/replace the entire coding for the BMW 1200: a friend of mine with another guy did it for a kit plane in South Africa.
They wanted a simpler version without all the cut-outs the BMW system has.
Be a bit inconvenient if you plane engine cuts out because it thinks the side-stand is down....:-}
But what they did isn't applicable to a motorbike.
Interesting... do you have contact details for this SA contact?
I'd like to discuss possibilities with him.
