***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Page 1 of 3 123 LastLast
Results 1 to 16 of 39
Thread: What's the best drill bit to use for broken stud?
  1. #1
    Member
    Join Date
    Oct 2013
    CHESHIRE
    Posts
    51
    Have to remove a broken stud on my 06 GSA , bottom bolt on the diagonal bar under the tank that then links to the rear frame and goes into the engine block , it snapped just below the surface so cannot get a nut onto it or weld , tried ez out and its been well soaked with penetrating stuff , have managed to drill 20mm out but still have 20mm to go and im getting through drill bits like their smarties .
    read loads on technique etc and have started small and then large but the last 20mm is out of reach for my small drill bits and I really do not want to have to take the engine out .
    If im lucky I will be able to retap to M10 but if not have next size on standby ,
    whats the best drill type to use , hss , cobalt etc as this bugger has to come out at the weekend so I can put the old girl back on the road after a year out .
  2. #2
    Join Date
    Sep 2007
    Buckley, North Wales
    Posts
    1,124
    A good drill at a slow speed with proper cutting oil.
  3. #3
    Appreciating Scotland Click here to find out how to Subscribe
    Join Date
    May 2005
    Glasgow, Scotland
    Posts
    8,297
    Cobalt first and last. +1 on Ian's comments.
    '83 BMW R100
    Yamaha S10
    '69 BMW R60 US
  4. #4
    Senior Member
    Join Date
    Apr 2014
    Ramsgate kent
    Posts
    2,036
    You need long drills not easy to find dormer presto are some of the best Iv got a few try the web someone must sell them but don't buy cheap ones I bent a drill bit the other day they should snap not bend lol
  5. #5
    Join Date
    Apr 2011
    Preston, England
    Posts
    265
    Long series cobalt, try Axminster - they supply what I use.
  6. #6
    Senior Member
    Join Date
    Apr 2014
    Ramsgate kent
    Posts
    2,036
    Axminster you mean lol your spell check or auto type thingy on
    http://www.axminster.co.uk/long-series-drill-bits
  7. #7
    Join Date
    Apr 2011
    Preston, England
    Posts
    265
  8. #8
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,431
    I find that cheap bits tend to shatter on awkward jobs like this. A fragment jammed down the hole is game over for drilling.
    I've had success with re ground masonry drills. Grind the tip to a metal cutting profile and use LOTS of cutting /cooling oil.
    If the newly drilled out hole isn't too large a thread insert can help. Something like a Timesert fastened in with high strength thread lock. This is an example http://www.carrlane.com/Catalog/inde...3C3B285356445B I have not used this brand.
    Sent from a widget that can't spell.
    08 R1200GSA
    76 Suzuki GT750
  9. #9
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,431
    I can't add to that post for some reason. It helps a lot if you can make a jig block or plate to keep the drill aligned. Also masonry can be more easily found in longer lengths
    08 R1200GSA
    76 Suzuki GT750
  10. #10
    Join Date
    Oct 2011
    Hertfordshire
    Posts
    1,602
    Dormer HSS drill bits and discard as soon as they lose their edge. Start drilling with a centre bit. Then use a 3mm bit to the required depth. Work upwards in 1mm sizes. Drill as slowly as possible with a firm pressure applied to the drill. Use plenty of cutting fluid or a thin oil. If you are doing it correctly, the swarf should come off like spiral springs.
    The mistake most make is that they drill too fast with blunt bits and no cutting fluid.
    Anyone riding slower than you is an idiot, and anyone riding faster than you is a maniac
  11. #11
    Member
    Join Date
    Oct 2013
    CHESHIRE
    Posts
    51
    thanks guys
    all really helpful , only reason the bolt had to come out was to get to the alternator which had seized and had the usual issues with corroded bolts on the alternator cover that wouldn't come off and bugger all space to get to anything .
    This will not beat me and she will ride again.
  12. #12
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    11,999
    Cobalt steel bits, loads and loads of coolant, slow speed and gentle pressure not over forcing the bit. Ideally use a left handed drill bit if you can get one with the chuck rotating backwards so if it bites it might turn out the threaded part if you are lucky.
    ADAM
  13. #13
    North Wales TRF Click here to find out how to Subscribe
    Join Date
    Apr 2006
    Cheshire, England.
    Posts
    7,169
    If you are asking this question, you should not be attempting the job, but leave it to a pro, who would find it easier to do if you haven't already made a rat's-ringpiece of the job by following 'advice' from a few non-pros on a forum.......
  14. #14
    Shep of the Dessert Click here to find out how to Subscribe
    Join Date
    Nov 2004
    Lleyn Penninsular
    Posts
    12,555
    Big problems happen when the bits blunt then burnish the cutting face, its just a few thou but can be proper hard, sometimes centre punching the burnished face can encourage the new bit to bite again, once its cutting again, keep it slow, keep it cool.
    A man with no boat is a prisoner.
    Faroese proverb
  15. #15
    Join Date
    Mar 2014
    Essex
    Posts
    50
    you can get a left handed drill bit (not a wind up)when you drill the stud they normally unscrew the stud as they grip
    http://www.ebay.co.uk/itm/Left-Hand-...item3a907bad8a
  16. #16
    Join Date
    Nov 2007
    Gloucester
    Posts
    3,142
    go with these:- http://www.amazon.co.uk/Neiko-13-Pie...ef=pd_cp_diy_0
    Left hand bits which will assist with getting a stud out, and titanium coated, again go slow lots of pressure and cutting/drilling fluid.
    Titanium coating wont last as long as a cobalt/steel drill as you can re sharpen them, but titanium is harder and if you keep them for just this sort of job they will last you for years.
    ''Rules are for the obedience of fools and the guidance of wise men''
    www.thektmforum.com for all your ktm needs
Posting Permissions
  • You may not post replies
  • You may not edit your posts
