***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Page 2 of 3 FirstFirst 123 LastLast
Results 17 to 32 of 39
Thread: What's the best drill bit to use for broken stud?
  1. #17
    # C2, T1 ,T3 & T4 = Halo Click here to find out how to Subscribe
    Join Date
    May 2007
    Coalville
    Posts
    1,570
    Quote Originally Posted by Tone 1 View Post
    you can get a left handed drill bit (not a wind up)when you drill the stud they normally unscrew the stud as they grip
    http://www.ebay.co.uk/itm/Left-Hand-...item3a907bad8a
    are you suggesting that as the drill 'bites' into the stud it'll wind it out??
    Best of luck with that one mate - a drill chuck only just holds the drill bit to create drive, if it held it any tighter it'd snap your wrist if it 'snagged'
    back to the problem- why not use a 'stud extractor'?? now one of these may just get it out if you have not knackered it already. these extractors get TIGHTER the further you can wind it in, in fact that tight that the stud gives up and starts turning out
    Poise - The art of raising an eyebrow - not the roof.
  2. #18
    Join Date
    Mar 2014
    Essex
    Posts
    50
    whatever m8, as for a stud extractor what if nothing is sticking out ?? easy outs are more trouble than they are worth especially when they snap
    " are you suggesting that as the drill 'bites' into the stud it'll wind it out?? " YES even on rusted ones use plenty of penetrating oil and let it soak
    http://www.youtube.com/watch?v=FYvaPbX1sT4
    http://www.youtube.com/watch?v=cGpc_X0wV8E
  3. #19
    Join Date
    May 2005
    cumbria, the real north west
    Posts
    5,913
    Quote Originally Posted by digga View Post
    they can turn the stud out, once you have drilled it sufficiently to remove the pressure, they won't generally though, stud extractors will only work, if you can get a good purchase on and you can heat the stud up to a cherry red, but if you could do that, then you should have before the stud snapped,
    on Gs'ers I normally just end up drilling progressively bigger, until I can either pick the remaining threads out and re Tap, or if it's slightly off centre, drilled out to helicoil size and re Tapped,
    a good centre punch is an essential start, get it in the centre of the stud and keeping it straight and true is much easier,
    had to drill out 6 studs this morning on a boxster, not fun!
  4. #20
    Senior Member
    Join Date
    Aug 2011
    Viet Nam
    Posts
    6,301
    Quote Originally Posted by ianboydsnr View Post
    Not much point in doing that. The stud is stuck fast due to corrosion, which in turn has effectively increased the stud diameter, the very reason it won't move. What's the point in applying heat when all it will do is increase the size further?
    Heat should be applied around the local area to the stud to create expansion of the female thread, not the male (stud) thread.
  5. #21
    Senior Member
    Join Date
    Aug 2011
    Viet Nam
    Posts
    6,301
    Ref post #21
    I didn't realise you couldn't edit a post in this section! I wanted to remove my post on the grounds I think I may have misunderstood what Ian was suggesting.
  6. #22
    Join Date
    Nov 2003
    Dublin, Ireland
    Posts
    15,063
    Quote Originally Posted by JayC View Post
    Ref post #21
    You can edit / delete your post up to an hour after you've posted it i think.
    Though others may have better advice;
    http://knowyourmeme.com/photos/157778-stop-posting
    appears bright from a distance / dim up close
  7. #23
    Senior Member
    Join Date
    Aug 2011
    Viet Nam
    Posts
    6,301
    Quote Originally Posted by Ogmios View Post
    No ' edit' button on my screen, either now or at the time of posting!
    Mods: Feel free to delete all post from, and incl, post#21.
  8. #24
    Join Date
    Nov 2003
    Dublin, Ireland
    Posts
    15,063
    Apologies to all.
    I should heed my own post and ... stop posting :
    As i see the 'rules' are different in The Font Of All....
    Sorry for that.
    Delete my 'contribution' Mods.
  9. #25
    Join Date
    May 2005
    Posts
    5,913
    My apologies for not making it clear, the heat is to both expand the stud and boil off any thread lock, which is used when manufactured, once cooled, forced or otherwise, to warm, stud should wind out without snapping!
  10. #26
    Join Date
    Aug 2008
    Newry, Co. Down
    Posts
    2,828
    Seriously:
    One with a left hand thread. Yes, and, of course, the drill running backwards.
    You have a good chance the broken bolt will self extract.
    Myke
  11. #27
    Join Date
    Jul 2010
    Overland and classic,vale of belvoir,Melton Mowbray
    Posts
    4,284
    Quote Originally Posted by Timpo View Post
    If you are asking this question, you should not be attempting the job, but leave it to a pro, who would find it easier to do if you haven't already made a rat's-ringpiece of the job by following 'advice' from a few non-pros on a forum.......
    i completely agree with the above
    i have lost count of the number of threads on this forum where chaps have dived in to drill bolts/studs out and have bollixxed the job completely
    you are not going to succeed in drilling a high tensile or forged bolt with cheap shit chinese drill bits.
    still,looking on the brighter side of things ,it keeps me in a job
  12. #28
    Join Date
    Mar 2010
    Slough
    Posts
    98
    With due respect what a croc of shit.
    I sell high end cutting tools to the engineering industry.
    Cobalt is the way to go but 9 times out of 10 you will fcuk it up as you will almost certainly not be able to drill dead center.
    My success rate on mates bikes is 6 out of 10.
    Then you will get a carbon steel left hand stud extractor which will break and you will be in double shit.
    Take it to somebody who knows what they are doing Steptoe for instance
  13. #29
    Absolutely, especially when the advise isn't to resharpen the drill but to chuck it
  14. #30
    Join Date
    May 2005
    Posts
    5,913
    Quote Originally Posted by Rare-Red View Post
    You sure your not getting a stud extractor and an easy out mixed up?
    You know, a stud extractor that grips around a stud, instead of an easy out, that screws anti clockwise into a drilled hole, then snaps, what kind of high end tools do you sell like
  15. #31
    Join Date
    May 2005
    Posts
    5,913
    Quote Originally Posted by Timolgra View Post
    My boss bought some drills from screwfix, we chucked them without even using most of them, a drill bit should not bend
  16. #32
    Extreme dog owner Click here to find out how to Subscribe
    Join Date
    May 2010
    Working away & Cornwall
    Posts
    810
    Click here to find out how to remove these ads
    I've had success in the past by drilling a hole the best I can (usually off centre) and then hammering something slightly tapered into the hole like a Torx bit then using an impact driver (manual type) and hammer.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
