***Please Note*** you can not create threads directly in this section. This section is made up of threads that have been moved here from other areas of the site
Results 1 to 13 of 13
Thread: BEARING RETENTION COMPOUNDS
  1. #1
    Join Date
    Sep 2009
    London England-Crete Greece
    Posts
    264
    ]Wanted to put this in "font of all wisdom" but not allowed. so have put it here as its my bike section.
    Have a Hitachi 9" angle grinder (G23SC2) with rear bearing failure (the cage has disintigrated allowing all the balls to run together
    (bit like the timong side bearing (3) of my T140v before I replaced it with a lipped roller). Have dismantled the machine and have
    sourced a new bearing and washers which hopefully are wending their way to Crete.
    The bearing is housed on the plastic casing and green sealant was used. i believe this is a bearing retaining compound. Have googled locktite but there several bearing retaining products.
    Can any engineers out there give me advice on what to use. Only want a small quantity as will prob not need it again. A loctite no would be helpful as I could possibly source it here without trying to explain what I want it for in Greek.
    As a general point is this stuff used in modern bike engineering
  2. #2
    Join Date
    Sep 2005
    Scotland
    Posts
    16,868
    If I am ever on life support - Unplug me......
    Then plug me back in..........
    See if that works .....
  3. #3
    Join Date
    Jun 2007
    Newark Notts
    Posts
    10,623
    I'm guessing that your best bet is a two part epoxy such as JB weld or similar but you really need to know what type of plastic makes up the housing to be sure
    Yesterday I dared to struggle Today I dared to win
  4. #4
    Join Date
    Dec 2012
    Cumbria, england
    Posts
    675
    Quote Originally Posted by Blackal View Post
    +1 top gear
  5. #5
    Join Date
    Jun 2007
    Newark Notts
    Posts
    10,623
    Quote Originally Posted by cbrgaz View Post
    +1 top gear
    Have you used it to bond a bearing to plastic ?
  6. #6
    Join Date
    Sep 2005
    Scotland
    Posts
    16,868
    Quote Originally Posted by bisbee View Post
    Just love these "challenging" posts................
    Instead of saying "Loctite may have an effect on some plastics" or similar, followed by a bit of reasoning.
    Al
  7. #7
    Join Date
    Jun 2007
    Newark Notts
    Posts
    10,623
    now
    Al
    I don't believe loctite or similar is meant to adhere metal to plastic hence why I suggested two part epoxy Plastic is by nature very smooth and as such provides little purchase for glues When attempting to glue to plastic it helps to know what type of plastic it is The environment will also be a factor eg grease/temperature etc
  8. #8
    Join Date
    Sep 2005
    Scotland
    Posts
    16,868
    It's not a case of "knowing better" - It's avoiding the "challenging" posts.
    With low-yield bearing-fit, I've never had to use anything more than light pressure with a screwdriver to remove the "cured" bearing fit from any material.
    Al
  9. #9
    Join Date
    Jun 2007
    Newark Notts
    Posts
    10,623
    Al
    Maybe I read the op wrong It appeared that the bearing was to be secured in a plastic housing
  10. #10
    Join Date
    Sep 2009
    Posts
    264
    Thanks for advice. Will go for 641. Only warning on plastics, is stress cracking, I presume because the material expands on curing to hold the bearing. This is a heavy
    duty industrial tool and the "plastic" is substantial so I have got no worries on that front.
  11. #11
    Senior Member
    Join Date
    May 2013
    Wellington, New Zealand
    Posts
    225
    Normal loctite will make the plastic crack. Simples.
    I agree with JB Weld or similar as a suggestion.
  12. #12
    Join Date
    Jun 2008
    scotland
    Posts
    4,801
    Simple ARALDITE GLUE also works
    still no deid
  13. #13
    Join Date
    Sep 2009
    Posts
    264
    My first thought as I have always had good results with Araldite when other so called super glues have failed. What put me off was would I be able to dis-assemble bearing if it needs renewing again?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
