That is my concern also, but on looking at the table posted by Roger, it would appear that the green section is the only section that would be reverted back to stock, the whole section appears to be at very low throttle openings.
The issue is that both parties have a vested interest as Roger is selling something as is John. The big difference for me is that Johns is only £60 as opposed to Rogers $198 + shipping.
Rogers arguement makes sense, as the 02 sensor I'd the last point of information feedback for the motronic, but cars and bikes with standard 02 sensors are chipped everyday, so it must be a viable option.
I'll agree, price matters. The AF-XIED was my idea as a plug 'n play replacement for the LC-1/LC-2 but it is not my product, I don't sell it. Nightrider engineered and built it (with my inputs on what BMWs need) and Beemerboneyard sells it.
And I'll also say that John is working hard, trying to do the right thing and knows how to competently read and write chips for the Motronic. What I've been trying to do, mostly unsuccessfully so far, is to get John to make better changes for the Closed Loop bike. Since he's convinced himself that I'm wrong on the points I've made (Closed Loop Mixture Adaptation), even though I have proven them, I haven't gotten very far.
You're on the right track. The green and yellow area are for throttle angles less than about 20 degrees. That is where almost all riding (cruising, even up to 100 mph) is done, so it is an important area to make a permanent improvement. That's issue number 1.
Issue number 2, what ever the average fuel addition that John makes in the Closed Loop area is--say he adds 4%--that much fuel will be removed in the Open Loop area. It happens like this: during Closed Loop, the Motronic figures out how much fuel had to be removed to get back to 14.7. That amount of fuel eventually gets added to the Long Term Trims in the Motronic. The Long Term Trims get applied to the entire map. It is City Hall and there is no sense denying it or fighting it.
An excellent solution for the R1150 would be as follows:
1. John puts in the time to figure out exactly which cells in the fuel map are Closed Loop and does not modify them.
2. He buys an LC-2 and sets it in Narrowband simulation mode at an AFR in the range of 13.8-14.1 (this is where most of us have settled out our closed loop fueling.
3. He adds fuel to the Open Loop parts of the chip where he feels it is needed. There are some very light throttle cells that are not closed loop and are quite lean. He may also want to add fuel to the higher power areas but I've already shown there is a lot there. Still, up to him.
4. He builds a chip with the timing adjustments for the entire map that he sees best and then records test runs with a GS-911 to confirm.
5. He makes no mods to the chip except in the fuel and spark maps because the other maps (correction factors for TPS, TPS rate, etc., etc.)
Users could start with that chip and add lambda-shifting if they wanted.
In truth, I think everyone should try lambda shifting. It adds a programmable, controlled amount of fuel to the whole map, and because richer mixtures burn faster the timing is effectively advanced about 2-3 degrees. It produces a very strong running bike, without having to get into the ECU. But each to his/her own.
