Sorry mistake May this yearThis is my remus hexocone euro 4 can i had fitted in June this year on my gsa !!!!!!!!!!
Sent from my SM-G950F using Tapatalk
Are all the affected bikes GS Adventure?
My reason for asking is that the GSA comes with the engine protection plate as standard. The plate blocks for the cooling airflow to the downpipes.
When analyzing the AFR of an unmodified engine it does not run on a steady 14,7. The engine varys between above and below 14,7, lets say the engine runs 50% richer and 50% leaner. Even if this average to 14,7, both richer and leaner means slightly cooler exhaust than from a steady AFR of 14,7.
Is there a chance that on some bikes, a slight drift in value from the O2 sensor will move the rich or lean side over to the 14,7 mark, thus warmer exhaust, and this, in combination with the protection plate that covers the downpipe for less cooling ads to the extra heat ? I.e, changing O2 sensors will do the trick?
Mine is an ADV but it was fine for the first 5 months. I havent fitted anything or changed anything. The pictures of that Remus Exhaust blow my theory that the exhaust flap might be sticking when hot if he's getting that in his silencer.
What does the bike do with a standard silencer on it, stock one from BMW, could there have been something wrong with the silencer from Remus.......
From your description is sounds like either the engine is misfiring or the exhaust valve are opening too early. In both cases that would mean fuel is burning in the exhaust.
Ive never rode a gsa before i got this and before this bike i had a zzr 1400 so yes the bike feels lumpy at times but im sure its just the boxer way. The after sales manager at Bowker bmw told me its not right after he road it, over to Southport. when he returned he put the bike in the garage and the pipes were glowing from front to back. His words were i could not ride that bike for a long length of time as it is really uncomfortable and the heat is to much.........but then engine must run badly then, surely you would feel something was not right............
There hands are tied they say they can only do any investigation work on the bike if germany authorize it, (that means they dont get paid) They have now taken a full ecu download which is at bmw berlin waiting to be analysed by the super dooper technical man who is on holiday till 3rd september. Check attached message from BMW-UKSurely he offered to look into it?
Hello Peter
Thanks for your patience while I looked into this for you.
I've spoken with Stephen Moyers from Bowker, and he's explained the situation with your bike to me.
I've been told that your issue has been raised with BMW Technical in Germany, and that due to it being an unusual issue, they need the expertise of a particular Senior Technician.
As you've been advised, this techinician isn't back off of annual leave until Monday 3 September.
While I can appreciate your frustration with not being able to ride your bike, I can assure you that this issue is being looked into - but it may take a little time to get to the bottom of the cause.
Steve has also told me that if you can get in touch with him, he'll be happy to look into arranging a courtesy bike for you to use while your bike is being repaired.
I'm sorry you can't enjoy your bike right now, but I'm confident that Bowker will be able to resolve this for you soon.
If there's anything else you need in the meantime, please let me know.
Rob
The standard can, you can fry an egg on it it gets that hot. It takes the skin off your fingers if you touch it. As for the remus it as a fixed baffle, Hilltop told my that the end of the baffle inside the exhaust is cupped like a trumpet mouth piece,on a much gentler scale.and when the exhaust gases hits it cause the gases to fan out to the sides before exiting the can. He described it to me like a meteor entering the atmosphere effect around that part of the can.I spoke to remus uk who have done 100s of hours of testing of this can on lc gs and gsa bikes which is homologated and have never seen anything like it. They replaced it with a titanium can under warranty which is in my garage waiting..........
The remus 8 is very similar looking to the standard can, in my opinionFairPlay to Remus for replacing it. I would be taking that loaner bike until yours is sorted. It also helps focus their minds on resolving it.
Any reason you got a hexacone rather than the Remus 8?
Plus I went for the carbon can because I thought the heat would dissipate quicker with the air flow.....The remus 8 is very similar looking to the standard can, in my opinion
Picture, please......I would agree it looks similar in shape except in black (because I’m biased as I have the black one).
