Page 1 of 2 12 LastLast
Results 1 to 16 of 17
Thread: Wilbers and Luggage???
  1. #1
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Disclaimer:
    I know there is a search function and ive looked but am struggling on my phone.
    Ive started the first leg of my touring journey and am visiting friends in Nottingham for a few of days.
    During the ride down. The rear seemed very low.
    Should i be adjusting the pre load?
    Im a noob at this, looking at the shock it looks like i can adjust the height and preload compression, but it looks different to coil overs ive adjusted in the past.
    If anyone can explain to me, what i need to do id appreciate it.
    Or if anyone is glued up in Nottingham and wants beer money to help me adjust it, id really appreciate it.
    Knew id forgotten to do something !
  2. #2
    Join Date
    Apr 2013
    Doncaster, England
    Posts
    13,725
    Quote Originally Posted by Magicmat View Post
    Disclaimer:
    Yep you need to adjust the pre load
    turn the Knob that is mounted on the frame clockwise and that will add pre load
    i would wind it all the way out first and start from there and keep adjusting untill it feels right
    No one nods at me cos they think I'm a Cnut
  3. #3
    Stay Frosty Click here to find out how to Subscribe
    Join Date
    Aug 2002
    Dorset
    Posts
    27,880
    as you increase load and ramp up the preload, you may want to give it a couple of extra clicks above standard of rebound adjustment. that's the knurled knob near the bottom of the shock. turn it clockwise looking from the bottom of the shock. don't go wild.
    leave the front shock on min pre load and stock damping position.
    i cant remember for sure what the standard position is for sure, but i think it might be 18 clicks back from fully in (clockwise).
  4. #4
    Deadhead Member Click here to find out how to Subscribe
    Join Date
    Feb 2005
    Nottingham England
    Posts
    28,678
    Ride height is something that you set pretty much as a one off although, TBH, I didn't know you could do this on WIlbers shocks (I'm sure mine don't have that adjustment?). On shocks that have adjustable ride height it's usually facilitated by 'screwing' the damper rod in and out of the top or bottom shock mount.
    Pre-load is the amount you 'load' the spring in order to compensate for the weight you put on the bike.
    On Wilbers this can by hydraulicly adjusted by a remote knob/wheel or by the more conventional way of screwing down a ring that the spring rests again (usually with a C spanner). The more weight you put on the bike the more preload you dial in.
    Assuming the shock is set up for your weight (Wilbers are usually custom built to your weight) then there should need to be little preload riding solo. Solo + luggage approx plus a quarter of the range, rider + pillion approx plus half of the range and rider + pilion + luggage approx plus 3/4 to max of the range (hope that makes sense).
    As you add more weight it can also help if you increase the damping a little bit.
    I'm in Nottingham and around much of the day Sat & Sun so happy to show you what I mean if that helps - PM me if you wan to pop over.
    Andres
    Quote Originally Posted by Charles Martel View Post
    One of the five imbeciles of the vainglorious big swinging dick types of the Harley section
  5. #5
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Photos ! Its alittle different to the stuff ive adjusted in the past
  6. #6
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Not sure if they have uploaded?
  7. #7
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Andreas, ive just bought the bike, and it was set up i think for a solo rider that was heavier than me.
    But now its got a pillion and lots of luggage !
    Im in woodthorpe this weekend if thats anywhere near you? Or i could come to you?
  8. #8
    Join Date
    Aug 2002
    Dorset
    Posts
    27,880
    they have uploaded.
    preload is done with the remote hydraulic adjuster, which you have but haven't pictured. it's on the other end of the hose shown in the last pic.
    damping is done with the knurled knob in pics 1 and 2.
  9. #9
    Join Date
    Feb 2005
    Nottingham England
    Posts
    28,678
    The red wheel at the base is damping.
    The hose off the top of the shock would suggest hydraulic preload adjustment - does it lead to a knob/wheel. If so, just wind that in 1/2 to 3/4 of it's full travel and that should be approx correct for you and luggage.
    If the hose leads to a small canister with two brass screws they are for low and high speed damping.
    If you start playing with damping settings make sure you record where you started from (assuming you are happy with where it started from).
    Andres
  10. #10
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Yeah i have a red preload knob, just wasnt sure if i should up the pre load on the spring.
    The wilbers are 40mm lower, if i can raise them at all that would be perfect
  11. #11
    Join Date
    Feb 2005
    Nottingham England
    Posts
    28,678
    Pop over to mine Wood'oop is 5 mins away on the bike - I'll PM you my details
    Andres
  12. #12
    07875 304772
    Join Date
    Sep 2003
    South Leicestershire
    Posts
    12,954
    Just for info re the rear wilbers remote preload....
    Mine looks like its got 50 clicks from fully out to fully in .....
    Just off in half an hour two up with camping gear... so wound mine up to 35 clicks..... will see how it goes
  13. #13
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Thanks guys really appreciate it.
  14. #14
    Join Date
    Jan 2002
    Redditch, Worcs
    Posts
    7,277
    If in doubt give Revs Racing a call at Halesowen, they are authorised Wilbers dealers and fitters and very helpful.
    2010 BMW R1200GSA
    2017 Kawasaki Z1000SX Touring
    2007 Suzuki Bandit 1250S
    1989 Jaguar XJS 5.3 Convertible
  15. #15
    Senior Member
    Join Date
    May 2014
    W. Yorkshire
    Posts
    187
    Revs racing and Andres ( Outtomunch ) both absolute stars and gents.
    Bikes sorted now, and i also got a cracking cup of tea,
    Thanks again all
    Matt
  16. #16
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,431
    Measure carrier frame height unloaded. (Weight on wheels). Load bike then turn up preload until the original height is restored.
    Alternatively crank it up and judge by leg reach to the floor. Damping might need to be upped as well but judge that from how the loaded bike rides.
    08 R1200GSA
    76 Suzuki GT750
Posting Permissions
  • You may not post replies
  • You may not edit your posts
